ABS Light
Old Jan 16, 2005 | 12:39 PM
mikester_91's Avatar
Default ABS Light
Alright, so my ABS light has been coming on for awhile now...and my brakes just lock up when i stop quick. The brake fluid is full in all resevoirs.... and when i hooked up the test connector, I got two quick blinks...a pause..and another quick blink. Does anybody know what this would be?? Any info. would be awesome.Thanks.
Old Jan 16, 2005 | 12:48 PM
Hawkze_2.3's Avatar
Default Re: ABS Light (mikester_91)
2 blinks, then 1 blink is "parking brake switch-related problem". Causes are these--
-Parking brake applied for more tha 30 sec while driving
-Brake fluid level in master cylinder too low
-Brake system light is blown
-Wiring is messed up between ABS module, brake system lights, parking brake switch, or brake fluid level switch.
Old Jan 16, 2005 | 12:54 PM
Hmmmm....so how would i go about fixing this?
Old Jan 16, 2005 | 12:58 PM
Hawkze_2.3's Avatar
Default Re: (mikester_91)
Well, common sense would tell me to make sure the e-brake is all the way down and that the switch is working (no e-brake light), then check brake fluid, and then if it's not fixed, check the wiring connection between the aforementioned components.
Old Jan 17, 2005 | 10:23 AM
My Parking Brake light on the dash doesn't work...because i took it out to put it in the check engine slot becuz it was burnt out...and ever since I did that, the ABS light has been comin on....so could that be the prob.?
Old Jan 17, 2005 | 06:28 PM
bump.
Old Jan 17, 2005 | 08:13 PM
The Phil's Avatar
go buy the stupid bulb...its probably cheap as hell anyways
Old Jan 18, 2005 | 01:14 PM
Dougs96SI's Avatar
I think that this is a common problem among 4th gen ludes. I have heard several people mention that their ABS light comes on at about 10 mph or 10 seconds of travel. My ABS light just stays on all the time, for some unknown reason.
Just a little reassurace that you arnt the first this has happened to. Ill be interested to hear all new information about this b/c i want to fix mine too .
95BG33PGSR
Apr 10, 2011 03:54 AM
dubzxallxstar
May 25, 2010 06:03 PM
supermotothud
Nov 10, 2008 04:09 PM
sushib01
Aug 30, 2004 03:43 PM
WeSsCyDeR
Oct 4, 2002 09:24 AM
