how to tell difference.
Old Jan 16, 2005 | 09:13 AM
hOndafienD 04's Avatar
Default how to tell difference.
between h series injectors....i replaced mine with "obd1" h22's and the h23s had the yellow tip at the bottom and the h22's had the green tip...does that sound correct? there was a thread on this a while ago, i tried searching but found nothing.
Old Jan 16, 2005 | 09:37 AM
satan_srv's Avatar
Default Re: how to tell difference. (hOndafienD 04)
why did you put h22a injectors in your h23??
Old Jan 16, 2005 | 09:44 AM
planning ahead.
Old Jan 16, 2005 | 09:47 AM
satan_srv's Avatar
Default Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">planning ahead.</TD></TR></TABLE>
planning for shitty performance and crap gas mileage?? you're now running 44% more fuel if you have no tuning device...won't take long to burn out your cat like that...
Old Jan 16, 2005 | 09:56 AM
Dulluthkid_19's Avatar
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">planning for shitty performance and crap gas mileage?? you're now running 44% more fuel if you have no tuning device...won't take long to burn out your cat like that...</TD></TR></TABLE>
Exactly, SRV...Take them out as soon as possible, get some injectors with the same flow rate!
Old Jan 16, 2005 | 10:00 AM
tonezilla's Avatar
i believe hondafiend is planning to go all motor, hence, maybe that is the reason why he has the bigger injectors .
i dont know if it will help, but i got a set of obd2 h22 injectors, and they have blue markings on the side of the plastic housing .
Modified by redxalien at 7:35 PM 1/16/2005
Old Jan 16, 2005 | 10:56 AM
i have no cat, and have a safc being delivered as we speak....i also have cams being made for me also as we speak, so the bigger injectors will benifit me in the future. and car will be tuned asap.
Old Jan 16, 2005 | 11:13 AM
satan_srv's Avatar
well whatever...there was no reason to put them in until you were maxing out your current injector duty cycle...and no reason to put them in until you could tune them, that's my opinion but this is about how to identify them so carry on...
Old Jan 16, 2005 | 11:15 AM
flyrod's Avatar
pirate is using H22 injectors in his hybrid. Just gotta tune for them.
Old Jan 16, 2005 | 11:17 AM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">well whatever...there was no reason to put them in until you were maxing out your current injector duty cycle...and no reason to put them in until you could tune them, that's my opinion but this is about how to identify them so carry on...</TD></TR></TABLE>
Well some people think differently from you bud; he's not gonna blow anything, so let him go.
He may have some big plans in the near future...
Old Jan 16, 2005 | 02:36 PM
i figured better safe then sorry...i rather run extremely rich, then be running dangerously lean....anyways....any1 know how to tell the difference? thanx
Old Jan 16, 2005 | 02:39 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">between h series injectors....i replaced mine with "obd1" h22's and the h23s had the yellow tip at the bottom and the h22's had the green tip...does that sound correct? there was a thread on this a while ago, i tried searching but found nothing. </TD></TR></TABLE>
that sounds right, honda used alot of 240cc injectors in alot of cars
but my h22 injectors look alittel fatter and have dark green tips.
Old Jan 16, 2005 | 02:47 PM
thanx
Old Jan 16, 2005 | 05:22 PM
tonezilla's Avatar
one way you can tell the difference is by measuring its resistance . obd1 are low impedance and should be around 1.5-2.5 ohms . while the obd2 are high impedance and should be around 10-13 ohms . hope that helps you out .
Old Jan 16, 2005 | 05:24 PM
well they plugged right in so that means they should be the a1's like satan said, so i guess they would be obd1's...and they have the blue color on the side where the dots are where my stock ones has them but in white...
Old Jan 16, 2005 | 05:26 PM
Speedra500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">i figured better safe then sorry...i rather run extremely rich, then be running dangerously lean....anyways....any1 know how to tell the difference? thanx</TD></TR></TABLE>
was your car running dangerously lean with your stock h23 injectors? running so rich will likely wash the oil from the poures on your cylinders walls and wear out your piston rings quickly.... just something to consider when trying to be safe rather than sorry
Old Jan 16, 2005 | 07:00 PM
^^întresting, and something to keep in mind...thanx for the heads up.
EG type GTR
Jul 12, 2006 04:25 AM
weak_tec
Feb 8, 2006 04:18 PM
spoonef
Jun 25, 2005 06:13 AM
Victor Penner
10
Dec 13, 2004 02:50 PM
earl
Nov 3, 2003 05:02 PM
