bog issues need help
Old Jan 13, 2005 | 04:35 PM
fre$h's Avatar
Default bog issues need help
sup guys,
i have a 96 prelude si swapped with a jdm h22a. and i'm having some bogging issues in the low rpms. if you give it full throttle at idle, it will sit at around 2-3k rpms and bog really bad. im throwing some codes also. vtec soloniod valve, and o2 sensor (lower o2 sensor).
i have 2 questions:
1. is this serious bogging caused by the o2 sensor. im just doubtful that it will fix the problem.
2. what are some symptoms of a bad vtec soloniod valve?
thanks guys, any help or suggestions apprieciated.
fre$h
Old Jan 13, 2005 | 04:39 PM
SuperSlow's Avatar
Default Re: bog issues need help (fre$h)
https://honda-tech.com/zerothread?id=1113634
it was only a bit further down the page.
And if you search, this is a multi-hit topic that is still somewhat mysterious. Read the threads that come up. You may find your solution there.
Old Jan 13, 2005 | 04:54 PM
fre$h's Avatar
Default Re: bog issues need help (SuperSlow)
anyone know about the vtec soloniod valve?
sohcboost06
Jul 19, 2007 02:56 PM
sireg6
Jun 2, 2007 02:55 AM
2KEXVtec
Mar 1, 2007 06:54 PM
BoostedsiR
Apr 20, 2003 06:53 PM
