instead of removing AC...
Old Apr 12, 2005 | 10:47 AM
Kashi's Avatar
Default instead of removing AC...
say, instead of removing the AC, would i still free up the horsepower if i just turned off my AC compressor via the 'A/C' button on the air vents? if not, why not? just curious!
Old Apr 12, 2005 | 10:49 AM
VisPreludeVtec's Avatar
Default Re: instead of removing AC... (Kashi)
removing the AC is not to free up horsepower, it is to free up weight
Old Apr 12, 2005 | 10:50 AM
Kashi's Avatar
Default Re: instead of removing AC... (VisPreludeVtec)
really? i thought it was for both. how much weight are we talking? must be a lot for everyone to be doing it.
Old Apr 12, 2005 | 10:51 AM
The Phil's Avatar
Isn't there a clutch on the AC? So when its off, its just like a dummy pulley?
And I think its somewhere around 100ish lbs.
Old Apr 12, 2005 | 10:53 AM
Kashi's Avatar
Default Re: instead of removing AC... (xthephilx)
whoa! that's a lotta weight!clutch on the ac pulley to be like a dummy pulley? i've never heard of that. but then, i've never heard of a lot of things.
Old Apr 12, 2005 | 11:02 AM
AndyD's Avatar
Yes, when the AC is not on...the pulley just spins. When you turn on the AC the clutch engages.
Pulling the AC will not yield any noticeable gains. It will just make you get tired of the car faster.
Old Apr 12, 2005 | 11:16 AM
mgags7's Avatar
the whole ac system weighs in at 32 lbs....not 100....
the pulley robs realistically no horsepower when the clutch is disengaged.....
Old Apr 12, 2005 | 11:17 AM
JTCdudeman's Avatar
Master H Technician
Default Re: instead of removing AC... (AndyD)
leave ur AC alone... youll regret it ahead... In the long summer days, or when you decide its time to move on... Yes, what they said is correct.
The AC compressor has a clutch that allows it to engage and disengage.. The pulley spins freely as long as the clutch is disengaged and does nothing. When engaged, it does have a slight power robbing property that allows ur AC system to function...
Ryan Cooles
Honda CR-V & Element
Jun 25, 2017 12:22 PM
nickelz34
10
Aug 31, 2009 07:55 PM
95EXcivicsleeper
Apr 25, 2004 10:43 AM
