hooking vafc up and code 22
Old Apr 14, 2005 | 03:09 PM
mt23vtecbb2's Avatar
Default hooking vafc up and code 22
i have a 96 si swapped to a 23vtec, i had a obd1 p13 with a skunk converson harness and the vafc. i swapped to a obd2 p13 and reinstalled the vafc and know i have a code 22 vtec problem. i have checked everything and im not sure what it might be. and yes i hooked up the vtm wire. so does any one have any thing else i can check or try?
Old Apr 14, 2005 | 05:11 PM
DarkBB4's Avatar
Default Re: hooking vafc up and code 22 (mt23vtecbb2)
ok jus thad this problem
the two wires concerned : yellow and WHITE, BLUE
What u should do is this... REWIRE
if needed (reccomend) using a thicker wire to make an extention to ensure a proper connection
blieve me it solved my problem
Old Apr 14, 2005 | 07:14 PM
Default Re: hooking vafc up and code 22 (DarkBB4)
so just thicker gage wire?
Old Apr 15, 2005 | 04:47 AM
DarkBB4's Avatar
thats what i did and it works
Old Apr 17, 2005 | 11:33 AM
got it fixed, apex has the ecu pin out drawing wrong, thay show the vtm wire hook up in the wrong place for a 96 obd2 lude. looked at my service manual pin out and called them to make sure it might be wrong. thay said it was. so look at it close if you are doing this on a 96 lude. later
S2KP
Oct 8, 2003 07:08 AM
.Beaver
28
Nov 19, 2002 04:31 PM
phiberoptik
Nov 14, 2002 12:05 PM
