Help Needed
Old Apr 12, 2005 | 05:30 PM
NeriVTEC's Avatar
Default Help Needed: Car won't start...
My car won't start and the check engine ight is one. already checked the ecu for a code and it has none and a friend of mine told me that he didn't hear the fuel pump activating when I put the switch on... Could this just be a fuel pump change and ready to go?
Modified by NeriVTEC at 6:55 PM 4/12/2005
Old Apr 12, 2005 | 05:35 PM
mgags7's Avatar
check the fusebox....
and please title your thread with what sort of help you need
Old Apr 12, 2005 | 05:36 PM
NeriVTEC's Avatar
Default Re: (mgags7)
I changed the fuel pump relay and nothing
Old Apr 12, 2005 | 05:45 PM
mgags7's Avatar
fusebox....like the ecu fuse....
Old Apr 12, 2005 | 05:57 PM
NeriVTEC's Avatar
Checked all the fuses..they are in perfect condition.
Old Apr 13, 2005 | 10:12 AM
NeriVTEC's Avatar
can anybody help?
Old Apr 13, 2005 | 10:20 AM
Elkins911's Avatar
Default Re: (NeriVTEC)
you need to test if fuel is getting to your injectors, your friend might not have tested the pump right. im sure he did though.... do a search.
your car needs fuel spark and compression to start. your car is turning over right? your compression should be good then.... are you getting spark? you need to test that too.... last is the fuel... then you need to go down the list of testing fuel problems.
fuel pumps are a pain in the *** and expensive. you might not need to change it, what if your looking in the wrong spot for the fuses? you have some inside the car and under the hood.
check your spark, then move to fuel....
Old Apr 13, 2005 | 03:12 PM
NeriVTEC's Avatar
Default Re: (Elkins911)
There is spark...we tested the pump and it worked...fuses are ok...could it be the connection from the ecu to the pump?
ek201
Dec 20, 2010 10:21 PM
Mref813
11
Dec 12, 2009 01:35 PM
bimmeracer
Jul 16, 2008 06:12 PM
jdm2teg
Oct 13, 2006 05:13 PM
EK9Blitz
Mar 27, 2004 08:49 AM
