Driverside Axle, help please
Old Apr 16, 2005 | 02:43 PM
Prelude-TeCh's Avatar
Default Driverside Axle, help please
I have a 92 lude si manual and i went to change the driverside axle and im having trouble pulling it out. I undid all of the blots, the spindol is aside i just cant pull out the axle, ive tryed to pry it but theres really to were to pry it out at, unlike the passanger side were u can just pry out the axle. ive searched allready on the topic and all i found was the passanger side how to but no driverside because they are different.
Any help would be nice because my car is sitting in the rain in peices.
Thanks
Old Apr 16, 2005 | 04:22 PM
9deuce9rr's Avatar
Default Re: Driverside Axle, help please (Prelude-TeCh)
when i did mine, once i got it outta the rotor, and unbolted it from the back of the block, u should either be able to just pull it, or get a flat and thin crow/pry bar and wedge it between the axle and the tranny and try to pry it. if that's wut u tried and it didn't work, then i'm not sure wut else u can do. good luck tho
Old Apr 16, 2005 | 04:31 PM
Default Re: Driverside Axle, help please (WhiteLude)
ok the axle is out.
Old Apr 17, 2005 | 12:16 PM
well i had to take out my driveshaft inorder to pound my axle off of it with a hamer, it was just 3 extra screws i had to take out and then it just came right out. just in case somebody ran into the same problem i did.
withoutlimitslude
29
Apr 1, 2022 03:21 PM
grjr
Aug 23, 2012 04:12 PM
EG6_978
Mar 18, 2009 02:38 PM
k3nnex
Feb 12, 2008 05:20 PM
Feb 19, 2004 08:54 PM
