OBD I Conversion / Emissions Question
Old Apr 14, 2005 | 01:56 PM
Dougs96SI's Avatar
Default OBD I Conversion / Emissions Question
Is it possible to pass an emissions test, with an OBD I conversion, and to go along with this question, will the conversion throw any codes (CEL's)?
Old Apr 14, 2005 | 03:42 PM
datac99's Avatar
Default Re: OBD I Conversion / Emissions Question (Dougs96SI)
Depends on where you are. I was looking into this recently and it seems that some areas of California (Damn tree hugging hippies!) you have to pass a smog2 test. For the smog2 they will want to connect to your diagnostic connector, and since it's no longer OBDII you fail.
This is from talking to my mechanic and reading up on the Internet, I have not called a smog check station and asked them yet. And I have been told by at least one reputable shop that the conversion would not be a problem unless I had to go before the state ref. If your not in CA, the general consensus is that your fine if you can pass the emissions portion.
Sorry that’s not much of an answer, maybe someone here has something more concrete.
-PM
Old Apr 14, 2005 | 04:23 PM
Monkey Fing a Coconut's Avatar
Default Re: OBD I Conversion / Emissions Question (datac99)
if u have a visual check you will fail, if you have to have the OBD II port scanned you will fail, however if it is only a sniffer test you will be able to take the test and possibly pass, it varies state to state, in cali theres all 3, in fl i think theres nothing, so it depends on your location
nesluopetan
Jun 14, 2007 12:23 PM
Stunna MIKE
25
Nov 24, 2005 04:37 PM
skafia
Jan 13, 2004 06:38 AM
