stalling...h22
Old Apr 13, 2005 | 04:45 PM
mxer518's Avatar
Default stalling...h22
hey i just finished my h22 swap into my 93 prelude si. it starts and idles fine but the second i give it gas it stalls out on me? dose anybody know whay this may be?
Old Apr 13, 2005 | 05:59 PM
mxer518's Avatar
Default Re: stalling...h22 (mxer518)
BUMP....i really need some help
Old Apr 13, 2005 | 11:25 PM
SKDRCR's Avatar
Which distributor are you using?
Did you set the timing with a timing gun?
Old Apr 14, 2005 | 03:09 AM
mxer518's Avatar
Default Re: stalling...h22 (SKDRCR)
im running the h23 dizzy, i figured its not the timing since it idles really smooth?
Old Apr 14, 2005 | 06:21 PM
mxer518's Avatar
BUMP...help please
Old Apr 14, 2005 | 06:42 PM
steveobb4's Avatar
Double check all of your connections, look for dirt/grease inside of the connectors.
Old Apr 14, 2005 | 06:53 PM
uncle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxer518 &raquo;</TD></TR><TR><TD CLASS="quote">BUMP...help please</TD></TR></TABLE>
What ECU are you running? Have you checked all the grounds?
Old Apr 14, 2005 | 06:55 PM
ludedude00's Avatar
Default Re: stalling...h22 (uncle)
check your injectors and **** like that..when you give it gas it mite not be shootin enough fuel or something, but i could be wrong.
Old Apr 14, 2005 | 07:37 PM
mxer518's Avatar
Default Re: stalling...h22 (ludedude00)
im running a p14 conversion ecu.... if the injectors were messed up i dont see why it would idle so smooth?
Old Apr 14, 2005 | 07:41 PM
uncle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxer518 &raquo;</TD></TR><TR><TD CLASS="quote">im running a p14 conversion ecu.... if the injectors were messed up i dont see why it would idle so smooth?</TD></TR></TABLE>
Have a friend with a p13 he could loan you?
Old Apr 15, 2005 | 03:10 AM
mxer518's Avatar
do you think that could be the problam? the ecu has the conversion chip in it.... i wouldent think it would start if the ecu were the problam...ill let u know if im goign to try the ecu..
Old Apr 15, 2005 | 04:27 AM
uncle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxer518 &raquo;</TD></TR><TR><TD CLASS="quote">do you think that could be the problam? the ecu has the conversion chip in it.... i wouldent think it would start if the ecu were the problam...ill let u know if im goign to try the ecu..</TD></TR></TABLE>
Yes, I'd definately try another ecu.
Old Mar 25, 2006 | 06:03 PM
92hondalude's Avatar
mine is doing the same thing. you think my p13 is bad? i bought it used
Championship
13
Feb 5, 2008 04:10 AM
skiracer8148
Jan 5, 2007 12:33 PM
90jdmcrxdude
May 13, 2006 02:24 PM
drummr6
Dec 15, 2005 10:18 PM
CivicRaping
13
Mar 22, 2005 10:38 PM
