fix, replace, or leave it alone
Old Apr 15, 2005 | 06:37 PM
speedjunky77's Avatar
Default fix, replace, or leave it alone
Removed my oil pan and notice the oil pickup in dented. Should I fix it (some how?) replace it, or just leave it alone? Thanks.
Old Apr 15, 2005 | 06:40 PM
SoOHiGH's Avatar
Default Re: fix, replace, or leave it alone (speedjunky77)
flat head and fix it. if that dont work then replace it.
Old Apr 15, 2005 | 06:50 PM
georgiajdm's Avatar
replace it now...I've seen some motors lock up b/c of oil starvation.
Old Apr 15, 2005 | 06:58 PM
AndyD's Avatar
Yeah, replace it . That is an important part.
If you need one, I have one available.
Old Apr 15, 2005 | 08:31 PM
Monkey Fing a Coconut's Avatar
Default Re: fix, replace, or leave it alone (AndyD)
also your lucky that it isnt giving u an oil pressure light and throwing your car in limp mode, i was in limp mode and saw a small dent in my oil pan, dent happened to be right under the pick up and was causing the low oil pressure, luckily it never dipped below 40-45 psi which is enough to prevent motor damage...
Old Apr 16, 2005 | 09:09 AM
LudeyKrus's Avatar
It's not TOO bad off.....
Just pry the dimpled part back out w/ a flat-head screwdriver. It's not a precision part; it's just a tube for sucking oil; as long as it's open enough to flow enough oil, and it's submerged in oil, it will act fine.
But if you must, I have one or two spares sitting around I'll sell ya cheap.
Old Apr 17, 2005 | 10:23 AM
high_revs's Avatar
Default Re: (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">replace it now...I've seen some motors lock up b/c of oil starvation.</TD></TR></TABLE>
yeah fix it dude...dont leave that like that.
Don Jefe
Nov 8, 2012 03:39 AM
si90rex
Jun 1, 2006 07:22 AM
sol2hatch
Mar 6, 2006 10:45 AM
Muckman
Jul 20, 2004 01:35 PM
EG*MonKEY
Nov 10, 2002 09:46 AM
