VTEC engagment
Old Apr 13, 2005 | 06:57 PM
PreludePhill's Avatar
Default VTEC engagment
ive noticed when i try to engage VTEC it doesnt kick like it should, when the rpms get around 5200 i hear it engage but like i said it doesnt feel normal , i do have an autometer oil pressure gauge installed could that be the problem?
Oh ya..
oil has 750 miles in it and is full
Modified by N2oH22 at 11:15 PM 4/13/2005
Old Apr 13, 2005 | 08:16 PM
The Phil's Avatar
Default Re: VTEC engagment (N2oH22)
5200? It should kick in at 5000. Any CELs?
Old Apr 13, 2005 | 10:48 PM
Lude454's Avatar
mine doesn't kick till 5250. with 5 gen it should jump in speed like hell when it hits that vtec might be someing wrong with it don't know
Old Apr 14, 2005 | 01:05 AM
andeh22's Avatar
yeah 5th gens should be around 5200.
you SHOULD feel it kick.. iuno. what else is done to it?
Old Apr 14, 2005 | 06:58 AM
silver97prelude's Avatar
Did you let your car warm up first? VTEC wont really work until the car is warmed up a little.
Old Apr 14, 2005 | 08:45 AM
The Phil's Avatar
Default Re: VTEC engagment (silver97prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver97prelude &raquo;</TD></TR><TR><TD CLASS="quote">Did you let your car warm up first? VTEC wont really work until the car is warmed up a little.</TD></TR></TABLE>
Not sure about how it works on the 5th gen, but if its not warmed up you won't hit vtec at all. No sound change or anything.
Old Apr 14, 2005 | 08:59 AM
azndng's Avatar
Default Re: VTEC engagment (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">
Not sure about how it works on the 5th gen, but if its not warmed up you won't hit vtec at all. No sound change or anything.</TD></TR></TABLE>
i agree. it vtec engages when the oil temp is up.
Old Apr 14, 2005 | 09:30 AM
SKDRCR's Avatar
Default Re: VTEC engagment (azndng)
Any CEL's?
Old Apr 14, 2005 | 09:31 AM
98TypeSH's Avatar
if you are rolling and try to mash from low 4th and hold till vtec it will sometimes feel slow. Thats normal.
If you have a CEL then its a totaly different story.
Old Apr 14, 2005 | 10:36 AM
Yea, no sound or anything, scared the **** out of me when I first got my car, thought I broke somthing.
Old Apr 14, 2005 | 10:46 AM
SiRLudeVtec's Avatar
I say check your TPS....because you know how vtec is only supposed to engage at a certain throttle point right? - well, if your tps is reading that you're in 30%-40% throttle....you won't feel vtec like you're supposed to. I don't know if i really explained it that well....but something like that.
Old Apr 14, 2005 | 10:48 AM
ludedude00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude454 &raquo;</TD></TR><TR><TD CLASS="quote">mine doesn't kick till 5250. with 5 gen it should jump in speed like hell when it hits that vtec might be someing wrong with it don't know</TD></TR></TABLE>
It's 5252 to be correct
Old Apr 14, 2005 | 10:52 AM
Default Re: VTEC engagment (ludedude00)
OH - i think Apexi has a new unit out- its called the I-moni or something like that....i think you should be able to read the throttle % off of there....or you could get a vafcII, but that would be a waste of money - or you can just check the voltage of the TPS....i know with my fourth gen, if i stay in first and rev it until vtec engages(not crossing 30%), i can hear the high cam setting come on, but i can't feel anything at all....just a thought.....mighty good one.... - but i don't really know how 5th gens work......just try....i think the voltage should be .5v at closed and 5v WOT....but mine usually only goes up to 4.5ish @ WOT
Old Apr 14, 2005 | 10:56 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedude00 &raquo;</TD></TR><TR><TD CLASS="quote">
It's 5252 to be correct </TD></TR></TABLE>
thats the rpm that all tourque and hp curves cross on a dyno plot,
according to the helms:
IAB solenoid activates on a P13 (91-96) at 4600, and 4900 on a P5M (97-01)
VTEC solenoid activates on a P13 (91-96) at 4900, and 5200 on a P5M (97-01)
Old Apr 14, 2005 | 04:30 PM
Monkey Fing a Coconut's Avatar
Default Re: VTEC engagment (prelittlelude)
no one has asked this yes, what is the oil pressure gauge reading at 5200 rpm??? oil pressure must be at least 55 psi for vtec to engage, along with traveling &lt;20 mph and above a certain temp
Old Apr 14, 2005 | 07:00 PM
nope no CELs,ill check the TPS wire b/c i just disconnected a Zex nitrous system that i hardly ever used so the wire might be loose, ill also check the oil pressure also and get back , thanks for the help.
Old Apr 14, 2005 | 07:20 PM
jscblulu's Avatar
i've got a vafc2 tuned for vtec to kick in at 4500
Old Apr 14, 2005 | 07:22 PM
uncle's Avatar
Default Re: (jscblulu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jscblulu &raquo;</TD></TR><TR><TD CLASS="quote">i've got a vafc2 tuned for vtec to kick in at 4500</TD></TR></TABLE>
It was tuned? If some idiot tuned your car and didn't know what they were doing by setting the VTEC engagement that low then there's your problem.
Old Apr 15, 2005 | 10:58 AM
Mine is set for 5000....is that too low? it hasn't been tuned that much....i tried doing a lot of it myself...its not bad.
Old Apr 15, 2005 | 11:20 AM
IHateJDM's Avatar
Default Re: (uncle)
I set mine to 4500 in my chipped p28, and it was a really smooth engagement (you couldn't hear the signiture vtec pop), but you could tell it was pulling harder. Just switched to a stock p13, and now my tires break loose in 2nd right when it hits. It's a huge change. I think i'm going to get it tuned on the p13 and move engagement to 4850.
Old Apr 15, 2005 | 02:57 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">5200? It should kick in at 5000. Any CELs?</TD></TR></TABLE>
Actually, its about 5200, the ecu sends the signal at about 5000, then once it moves through everything and the cams start working, then it kicks in But anyways, is all the wiring to your vtec solenoid and everything okay&gt;?
JSpekBB4
Oct 30, 2007 10:23 PM
93FastLs
Mar 25, 2005 12:24 PM
JDMb16ef
Oct 24, 2004 07:10 PM
srehmat02
Sep 17, 2004 02:24 AM
SpeedGyrl
Mar 16, 2003 04:23 PM
