Limp Mode?
Old May 21, 2005 | 08:35 AM
Jeff99Base's Avatar
Default Limp Mode?
I ran into a problem /w my 99 prelude last night. While not in gear the car would not rev past about 6,500. If I put it in gear and was actually moving the car would rev all the way to redline. I checked the oil level and it was about half a quart to 2/3 quart low. I added oil but still am having the problem, what could be causing this?
Old May 21, 2005 | 08:38 AM
RemerLex11's Avatar
Default Re: Limp Mode? (Jeff99Base)
why do you want to rev it past 6500 when you're not in gear anyway?
that's gonna make for a real shitty launch
Old May 21, 2005 | 08:40 AM
Jeff99Base's Avatar
Default Re: Limp Mode? (Matt5745767)
I wasnt trying to launch at that RPM, I just happened to notice that the engine would not rev past that out of gear.
Old May 21, 2005 | 09:01 AM
RemerLex11's Avatar
if you were in limp mode you wouldnt be able to rev to the redline while moving.
Old May 21, 2005 | 10:07 AM
4LugR's Avatar
the car has a governor that wont let u rev past that while not in gear, cuz mine does the same thing, it doesnt want u to try to launch it from hi *** rpm's, cuz itll cause damage... but ne ways, u kno its not good to rev that high when not in gear right..... its really bad on ur tranny and clutch..
Old May 21, 2005 | 10:57 AM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff99Base &raquo;</TD></TR><TR><TD CLASS="quote">I ran into a problem /w my 99 prelude last night. While not in gear the car would not rev past about 6,500. If I put it in gear and was actually moving the car would rev all the way to redline. I checked the oil level and it was about half a quart to 2/3 quart low. I added oil but still am having the problem, what could be causing this?</TD></TR></TABLE>
WOAAA, you are the first one who discover this! Congratulation!!! Anyway back to the story, it is normal when the car is in Neutral and you can't rev high. Mine does the same thing. Don't need to be worry or concerned about it.
Old May 21, 2005 | 11:40 AM
matix's Avatar
Default Re: Limp Mode? (xbn83)
Uh no this has been asked numerous times.
kamranm3
Nov 5, 2010 07:36 AM
Razr2
15
Jan 1, 2008 10:24 PM
Adam.
32
Dec 12, 2006 09:51 AM
accordtunerx
Jun 12, 2005 08:40 PM
1SlowSi
Feb 25, 2004 05:59 AM
