Possible Head Gasket Problem?
Old May 23, 2005 | 04:27 PM
preludeguy_92's Avatar
Default Possible Head Gasket Problem?
My problem is my engine idled just fine the only problems were that the oil and coolant were mixing. So i took off the head and the head gasket looks ok (maybe i overlooked something). There is also some black ash like build up on the top of the pistons. I have no idea what to do. Im thinking ill just change the head gasket and see if that fixes the problem.
all comments are appreciated.
Old May 23, 2005 | 04:49 PM
eMpAtHy's Avatar
Default Re: Possible Head Gasket Problem? (preludeguy_92)
oil + coolant mixing=HG problem. unless you were drunk and poured oil into your radiator or coolant into your crankcase. the black ash stuff you see is carbon build up. this happens to all cars. dont worry about it. you can use seafoam to get rid of it or most of it. make sure ur head/block is not warped.
Old May 23, 2005 | 05:59 PM
Default Re: Possible Head Gasket Problem? (eMpAtHy)
if it is not out of specs i can just have it machined though right
Old May 23, 2005 | 06:39 PM
prylwd's Avatar
If your not sure about the HG have someone else look at it (even though when coolant and oil mix it is almost always the HG). Like someone else said take a straight edge to the block and head before putting back on.
01_civic
Classic Hondas
Jun 3, 2012 06:58 PM
Hondapreludeg
Aug 24, 2010 12:51 PM
turbomike
Jan 19, 2010 08:27 PM
delbert
May 4, 2009 09:40 AM
BluLude
Jul 22, 2005 06:20 AM
