Camshaft installation problem
Old May 25, 2005 | 09:11 AM
preludeguy_92's Avatar
Default Camshaft installation problem
I just replaced the head gasket on my h23. I torqued everything down in order of the helm manual but the exhaust cam seems to be tighter than the intake cam. The intake cam seems right the exhaust cam just doesnt turn easily. I am just wondering if when i reset the rockers if it would fix the problem?
Old May 25, 2005 | 09:20 AM
Hawkze_2.3's Avatar
Default Re: Camshaft installation problem (preludeguy_92)
Did you do a valve adjustment??
Old May 25, 2005 | 09:22 AM
2lude4u's Avatar
If by "reset the rockers" you mean adjust your valve lash, Yes. It's more than likely the some of your rockers are rubbing against the cam, making it difficult to rotate. After you adjust your valves it should be better.
It's also possible that maybe the exhaust cam didn't get lubed as well as the intake cam, so there is a little more metal on metal contact occurring.
Old May 26, 2005 | 09:07 AM
Default Re: Camshaft installation problem (2lude4u)
i figured it out, the distributor was 180 degrees off so i fixed that and walla, golden
XiOus271
Jan 20, 2006 10:36 AM
NOSed_b18b
Feb 22, 2002 05:35 AM
