Clickity Click
Old May 26, 2005 | 07:16 PM
kelley_james's Avatar
Default Clickity Click
Recently i've noticed a small clicking noise coming from the tranny i suppose. If, for example, you slowly let out the clutch while idleing, it seems as the pressure plate engages, a small clicking noise happens (just once). the car drives the same and i haven't noticed any problems while driving. i'd like to figure out what this is b4 it turns into something bigger. thank in advance!
Old May 26, 2005 | 07:18 PM
AndyD's Avatar
Default Re: Clickity Click (kelley_james)
Check the axles.
Old May 27, 2005 | 04:40 AM
Default Re: Clickity Click (AndyD)
what should i check on the axles.
Old May 27, 2005 | 08:43 AM
JonGP4's Avatar
forget the axles, they click many times when making sharp turns under a load.. i think its just the throw out bearing.. they usually make noise.. unless you feel like droping the trany for something very minor .. live with it.
Old May 27, 2005 | 10:13 AM
Default Re: Clickity Click (JonGP4)
what are the chances of the throw out bearing leading to a more major problem?
Old May 27, 2005 | 10:18 AM
Sephro's Avatar
it will make a lot more noise before it's a real issue.. That is if the TOB is bad..
It could just be the TOB coming off the pressure plate...
Old May 29, 2005 | 04:18 PM
Default Re: Clickity Click (Sephro)
at risk of sounding like a newb, what does that last sentence entail? the tob coming off the pressure plate. do you mean when it engages?
ltzracer
Aug 29, 2007 05:14 AM
capsu!e
Jan 16, 2007 12:11 PM
4everVtec
11
Nov 14, 2006 04:44 PM
DA jeshy
Mar 6, 2006 12:24 PM
TheHater
15
Jan 22, 2003 06:46 PM
