Question on toe alignment!!!
Old May 21, 2005 | 10:48 AM
xbn83's Avatar
Default Question on toe alignment!!!
I just got alignment done on '99 Prelude. For example here is my TOE "before" and "after" on the front left wheel:
After Before Specified Range
0.03 -0.15 -0.08 0.08
My car is lowered about 1.5" front and 1.3" rear, and I don't have camber kit. I understand that TOE is the main thing that kills the tires. I hear a lot of people say that the TOE has to be zero out to prevent the inside wear. My question is that does it have to be exactly at 0 or just within the spec range is fine?
Modified by xbn83 at 3:01 PM 5/21/2005
Old May 21, 2005 | 10:57 AM
The Phil's Avatar
Default Re: Question on toe alignment!!! (xbn83)
0 would be the best, but the spec range is there for a reason, and it should be fine.
Old May 21, 2005 | 11:06 AM
xbn83's Avatar
Default Re: Question on toe alignment!!! (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">0 would be the best, but the spec range is there for a reason, and it should be fine.</TD></TR></TABLE>
Thanks! The TOE on all 4 wheels is within spec, but some of the wheel's CAMBER isn't. Should I worry about that?
Old May 21, 2005 | 11:55 AM
equinox's Avatar
What are your specs on your camber?
Old May 21, 2005 | 12:26 PM
xbn83's Avatar
Default Re: Question on toe alignment!!! (lude_roller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_roller &raquo;</TD></TR><TR><TD CLASS="quote">What are your specs on your camber? </TD></TR></TABLE>
Specified Range Front:
-1.0 1.0
Mine:
Left -0.9
Right -1.5
Specified Range Rear:
-1.8 0.3
Mine:
Left -1.8
Right -2.1
Any comment or suggestion?
Old May 21, 2005 | 07:20 PM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">Specified Range Front:
-1.0 1.0
Mine:
Left -0.9
Right -1.5
-1.8 0.3
Mine:
Left -1.8
Right -2.1
Any comment or suggestion?</TD></TR></TABLE>
the rear is kind of off. 2 degrees is a lot.
Old May 21, 2005 | 07:57 PM
The Phil's Avatar
Default Re: Question on toe alignment!!! (eMpAtHy)
Get that fixed.
Old May 22, 2005 | 02:20 PM
xbn83's Avatar
bump
jdmztrane
Jul 19, 2008 06:20 AM
Civicse
Dec 11, 2006 10:22 AM
G2_Fella
Oct 1, 2006 07:24 PM
scoobyghost
Aug 17, 2003 07:28 AM
Chris N
Oct 18, 2002 08:04 AM
