rebuild engine
Old Mar 23, 2006 | 10:10 PM
gamblezhang
Guest
Posts: n/a
Default rebuild engine
i have a 1997 lude with 142k. if i want to rebuild it. what parts do i need to buy? rebuild it to oem standard. i searched...tooooo many come up..and my 56k can't handle.
Old Mar 23, 2006 | 10:12 PM
onefastrx7turbo's Avatar
Default Re: rebuild engine (gamblezhang)
56K??!?! I didnt know they still used that! Anyhow, there are a number of places you can find OEM rebuild parts. On a side note, unless you have low compression, I wouldnt worry about a rebuild yet. Let's remember, this is a Honda and you have less than 150,000 miles. Like i said, unless its low, smokes, drinks oil or whatever. id rock it until you see signs of a worn engine.
Old Mar 23, 2006 | 10:40 PM
hu's Avatar
hu
Do you want oem spec or aftermarket performance?
Since you have to pull the head to replace the head gasket, you might as well do a 3 angle valve job at a minimun. Maybe Port & polish if you have the $$. Definitely get new valves (supertech) springs & retainers (supertech). Think about a pair of type S cams or Crower Cams or Skunk 2 cams. All will net you power.
The block. Depending on $, sleeve the block. If $ is tight, get type S pistons. Definitely get your crank balanced and polished. New rods might be in order as well. Crower is good. Although I prefer Pauter.
Really really think about getting a good header & exhaust system for you car. I recommend SMSP. http://sms-products.com/index.html
Good luck. Make sure you ask questions...as many as you need to, before you tear that engine down. Keep us posted.
Old Mar 24, 2006 | 12:47 AM
gamblezhang
Guest
Posts: n/a
i only have 2k$ for the parts. what can i get?
Old Mar 24, 2006 | 02:51 AM
hu's Avatar
hu
Can you pull the head off? Basically, will you be able to do any of the labor? Or does the 2k include labor?
Old Mar 24, 2006 | 05:35 AM
gamblezhang
Guest
Posts: n/a
Default Re: (hu)
2k$ parts...friend do the labor.
Old Mar 24, 2006 | 07:50 AM
thedread's Avatar
Default Re: (gamblezhang)
Why are you rebuilding? I had over 200,000 miles on my engine with no problems or loss of compression. When we tore into the engine ther was virtually no wear on the internal parts. So make sure you need to rebuild, before you do it. Your other option is buying a low miles JDM engine from a reputable dealer.
Old Mar 27, 2006 | 11:13 AM
rice a roni's Avatar
Default Re: (thedread)
yeah dude...foreals...i just hit 270k on my civic and i burn/drip like 1-1 1/2 quarts per oil change.
phelpsj2
Jan 16, 2012 05:22 PM
Trey
12
Mar 24, 2011 01:06 PM
CRX MASE
Apr 21, 2009 07:42 PM
Demonlude
Mar 13, 2007 01:07 PM
johnzm
Oct 14, 2003 11:29 AM
