CEL: Code 1
Old Mar 19, 2006 | 05:10 AM
Jeffrey9's Avatar
Default CEL: Code 1
02 sensor. Popped up a couple days ago. Heres what I know:
There was a pisspoor wiring attempt to tee a wire off the white/black wire on the ECU for an Air/Fuel gauge. I've replaced the wire in hopes that that was the issue but it did nothing. and the light's still on.
I hear it's rare for the O2 sensor itself to actually fail, so what else should I be checking?
Thanks.
Old Mar 19, 2006 | 06:25 AM
mgags7's Avatar
it is in no way rare for an o2 sensor to fail
first, check continuity over that wire all the way from the sensor to the ecu, if continuity is good, then try a new sensor, if not, check that wire better
Old Mar 19, 2006 | 12:02 PM
flipwhip's Avatar
Default Re: (mgags7)
I had a bad o2 sensor, I dont think its that rare either.
Old Mar 21, 2006 | 05:14 AM
Jeffrey9's Avatar
Default Re: (flipwhip)
Like I said, just what I heard.
I'll check the wire all the way from the harness to the sensor and get back with ya.
Old Mar 21, 2006 | 08:26 AM
98TypeSH's Avatar
Default Re: (Jeffrey9)
did you reset the ECU after you fixed this wire ? If not, reset before you replace.
burnitdown
Apr 30, 2007 01:27 PM
RobbieG35
Jun 21, 2006 07:29 AM
xmd
Oct 12, 2003 10:38 AM
FusionITR
Feb 28, 2002 11:50 PM
