Installing Strut Bar
Old Mar 20, 2006 | 03:28 PM
h22vt's Avatar
Default Installing Strut Bar
Im sorry if this is stupid but will this huge hole prevent me from putting on a strut bar?
Old Mar 20, 2006 | 03:30 PM
IIVIIoOkY's Avatar
Default Re: Installing Strut Bar (h22vt)
probably not but that hole will probably hurt you in the long run....
Old Mar 20, 2006 | 03:34 PM
yoohoo's Avatar
Default Re: Installing Strut Bar (xLude97)
dammm! what was that hole for?
Old Mar 20, 2006 | 03:38 PM
ChrisRicketts's Avatar
Default Re: Installing Strut Bar (Personal Information)
wtf? why would someone cut a hole there on purpose?
Old Mar 20, 2006 | 03:41 PM
h22vt's Avatar
hell if i know, it was like that when i got it. why would it hurt in the long run?
Old Mar 20, 2006 | 03:53 PM
HxClude's Avatar
Default Re: (h22vt)
The strut bar attaches to those three studs that are right next to the hole. Install shouldn't be a problem in that respect. but since all that metal has been cut out, I'm not sure if the angle of the shock tower itself has changed or not (if its bent or warped at all). May take some muscle to get that bar bolted down.
I'd recommmed getting some sheet metal welded over those cutouts, by the way.
Old Mar 20, 2006 | 04:21 PM
CD6's Avatar
CD6
Wow.. thats is just weird. The strut tower is a very important part of your frame. Get it looked at by a good bodyshop ASAP
Old Mar 20, 2006 | 04:22 PM
Altilude's Avatar
Default Re: (HxClude)
yeah as stated you should be fine, although i would question the structural integrity of those towers.
I hate to jack the thread but sorta have a stupid question about strut bars myself - on the tanabe website it says that often strut bars are installed wrong, without the car jacked up (tires in the air) and without the preload applied. I was just curious which direction is this pre-load supposed to be applied - I assume it's inwards, ie: ----> <---- (in escense making the strut bar shorter NOT longer to preload) can anyone clarify? my instructions were in japanese. apologies for the partial-jack.
Old Mar 20, 2006 | 05:27 PM
h22vt's Avatar
thats a good question, i would like to know also
Old Mar 20, 2006 | 05:59 PM
getbig's Avatar
Anyone notice the driverside upperball joint is adjustable but the passengers is not?
Old Mar 20, 2006 | 06:05 PM
nonvteclude's Avatar
if you get a neuspeed tower bar it connects to the upper control arm bolts
Old Mar 20, 2006 | 06:06 PM
IIVIIoOkY's Avatar
Default Re: (getbig)
yeah people were saying that before when he posted the pics of his DIY machine shopping of his car lol.
Old Mar 20, 2006 | 06:13 PM
M2B4's Avatar
Default Re: (xLude97)
youll be ok to install one but why? you wont be gaining much due to the massive holes next to it
Old Mar 20, 2006 | 06:20 PM
h22vt's Avatar
ive asked this before, is there anything i can do to fix this? if i go to a bodyshop and get them to wield the hole it would it be better?
Old Mar 20, 2006 | 06:28 PM
M2B4's Avatar
Default Re: (h22vt)
yeah that would bring back some of the strength have them weld a plate of equal thickness and strength
Old Mar 20, 2006 | 06:30 PM
Prelude_2_NV's Avatar
Default Re: (M2B4)
Those were caps there before. I'm guessing the old owner removed them to allow for more suspension movement. This is what the upper control arm hits when you lower your car more than 3".
As for the strut bar, you'll be ok to install them.
Old Mar 20, 2006 | 08:54 PM
prelude1897's Avatar
I hope you got that car at a good price...Whomever had it before you was a dumb *** for cutting those holes
Old Mar 20, 2006 | 09:23 PM
kb798's Avatar
The previous owner probably had a camber kit that was banging against the tower.
Old Mar 20, 2006 | 09:50 PM
ImPuLsIvE's Avatar
WTF is up with that ****!! Dude, get those holes welded up NOW. As if that car is legal to drive like that.
Old Mar 20, 2006 | 11:42 PM
integra pride's Avatar
my god....WTF...*speechless*
don't worry about the struts bar...
worry about that hole first
Old Mar 20, 2006 | 11:47 PM
soundbomber's Avatar
your car was either a straight up racecar before, or had airbags
Old Mar 21, 2006 | 12:17 AM
hu's Avatar
hu
Get it welded for real!
Old Mar 21, 2006 | 03:49 AM
h22vt's Avatar
before it had like a 3 1/2" drop on 19"s so im pretty sure thats why the hole is cut out.
MechEng
May 29, 2011 06:49 PM
mrdeadman
Apr 20, 2006 04:24 PM
dohcdelsol
Jun 1, 2004 06:06 PM
jagged4698
Feb 22, 2004 07:39 PM
