Ate Super BLue fluid
Ok probably this weekend im going to be switching over to this fluid. My question is how much will I need to bleed the whole system ? Also does anyone have any experiences with this fluid, good/bad ?
Re: Ate Super BLue fluid (iLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLude »</TD></TR><TR><TD CLASS="quote">only difference is higher boiling point. They only time you'd probably notice a difference is on a track...</TD></TR></TABLE>
Yeap, don't use this fluid on the street, unless you track your car. Race fluid has a tendency to draw in moisture faster, thus reducing the boiling point. Just get that castrol brake fluid, its more than fine for the street. Ford HD brake fluid is pretty awesome as well, a lot of racers I know use it.
If you do use this in a street car, you may want to change it more frequently (because of the moisture issue pointed out by Honda318dx). I completely flush the fluid in my Prelude and 951 either every 6 months or 2 track weekends (whatever comes first).
CivicSiRacer
53
04-09-2002 08:31 PM
