what is this? please help
Old Mar 22, 2006 | 10:57 AM
h22vt's Avatar
Default what is this? please help
i might be stupid but what is the little nut/washer thing? it wont go on my shifter, i dont want to force it, when i took the other one off it came right off.
Old Mar 22, 2006 | 11:12 AM
syntax.'s Avatar
Default Re: what is this? please help (h22vt)
im guessing its just a lockwasher because your new shifter doesnt have a setscrew. just find a nut that fits, screw it onto the shifter first, screw on the **** until its at the right height and orientation, then tighten the nut against the shifter ****
Old Mar 22, 2006 | 01:25 PM
SnlpeR's Avatar
put that nut upside down on your shift lever first then screw the **** down
tighten the lock nut when the **** is aligned right
without the lock nut...your shift **** will be crooked looking
Old Mar 22, 2006 | 01:27 PM
epoch707's Avatar
Default Re: what is this? please help (syntax420)
exactly, since when you screw in the shifter it won't always align so that the gear numbers will read straight ahead, you need to adjust the locknut so the numbers display straight.
btw i got the same shift ****, quality is superb, its awsome
Old Mar 22, 2006 | 01:38 PM
Saosinx's Avatar
Default Re: what is this? please help (epoch707)
it won't go on cause it's threaded in reverse. turn it upside down, and start spinning then set the **** on and then spin the nut and lock that beauty in place!
PatrickGSR94
Apr 4, 2010 09:03 AM
B16Jacques
Sep 20, 2008 09:15 AM
lickety_britches
Aug 3, 2007 06:25 AM
DannyITR
May 28, 2007 09:29 PM
Dunc
Jan 14, 2007 02:16 PM
