engine bay cleanup!?
Old Jul 11, 2006 | 11:07 PM
MadCityLude
Guest
Posts: n/a
Default engine bay cleanup!?
I am cleaning up my engine bay cause I am tired of working around all the extra BS.
I am already removing PS, cruise, and AC is gone!
What other unnecessary stuff is under the hood of our cars!
I need to keep it a daily driver, and want it to run as stock as possible, but am not concerned with emmisions!
Thanks for the help
Old Jul 12, 2006 | 04:26 AM
shutta's Avatar
you oculd relocate your battery to the trunk, or I have seen some people mount the battery down further. if you remove the battery tray, and the brace underneath, you can make some l bracket and drop it a good 6-8 inches. looks cleaner, but if you really didn't want that, just get a bettery box and throw it in the trunk.
extend your fusebox to go under your passenger side dash, re-route wiring harness/extend wires so they go where they aren't very visible.. i'm probbaly forgetting some things, but clean you engine bay after ou are done with everything, it'll look 10x nicer when you do that
Old Jul 12, 2006 | 07:57 AM
MadCityLude
Guest
Posts: n/a
Default Re: (shutta)
Yea, I will do the battery relocation for sure!
I will look into the fuse box relocation (gotta see how hard it would be)
What about any other sensors etc. I can get rid of? (without affecting driveability or CELs)
Thanks again
Old Jul 12, 2006 | 08:06 AM
Hawkze_2.3's Avatar
Default Re: (MadCityLude)
You can still remove the EVAP system, ABS, starting air valve, washer squirters, AC wiring harness and you can move a lot of stuff so it's hidden like the EGR and MAP sensor for example.
Old Jul 12, 2006 | 08:13 AM
MadCityLude
Guest
Posts: n/a
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">You can still remove the EVAP system, ABS, starting air valve, washer squirters, AC wiring harness and you can move a lot of stuff so it's hidden like the EGR and MAP sensor for example.</TD></TR></TABLE>
Never had ABS, AC is completely gone!
What is the EVAP? Where is it?
And starting air valve? whre is it and what is its function? will it throw CELs if I remove it?
Old Jul 12, 2006 | 08:18 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">
And starting air valve? whre is it and what is its function? will it throw CELs if I remove it?</TD></TR></TABLE>
You got the AC relay things on frame behind the headlight?
EVAP is the fuel tank evaporative emissions control system. The little charcoal canister on the firewall and a bunch of lines and stuff.
Starting air valve gives extra air on startup...useless. It's a little valve on the IM with a vacuum line going to the intake before the throttle body.
Old Jul 12, 2006 | 08:28 AM
MadCityLude
Guest
Posts: n/a
I will check on the AC stuff more after I get cruise out completely!
EVAP - yea I am pretty sure I took that out! it had a couple vac lines and another larger diameter hose running down to to bottom of car for draining or something?
Any chance of a pic of the valve your speaking of? do I need to block anything off? Does it cause a CEL?
Old Jul 12, 2006 | 08:32 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">I will check on the AC stuff more after I get cruise out completely!
Any chance of a pic of the valve your speaking of? do I need to block anything off? Does it cause a CEL?</TD></TR></TABLE>
Yeah, the EVAP has like 3 lines, 1 seperate solenoid, the canister and a hardline that goes aaaalllll the way back to the gas tank.
I'll try to get a pic of that valve in a sec....and you do need to black off a hole. I just cut a little piece of CF and bolted it on...
Old Jul 12, 2006 | 08:55 AM
Hawkze_2.3's Avatar
Here's the valve--
And here's a pretty cleaned up engine bay despite the f'ed up valve cover--
Hopefully we'll see a Prelude traction bar setup soon and my front mount will be gone when I get a chance to install the Innovative rear mount, and that'll help out even more.
Old Jul 12, 2006 | 09:00 AM
MadCityLude
Guest
Posts: n/a
Thanks Hawkze!!!
I will take a look at that this afternoon!
Old Jul 12, 2006 | 11:03 AM
esedulerp5tenin's Avatar
so hawk, you have no windshield washers/fluid??
what happens when you get **** on the windshield?
Old Jul 12, 2006 | 11:08 AM
Hawkze_2.3's Avatar
Default Re: (esedulerp5tenin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">so hawk, you have no windshield washers/fluid??
what happens when you get **** on the windshield?</TD></TR></TABLE>
I use a little elbow grease.
Old Jul 12, 2006 | 11:09 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I use a little elbow grease. </TD></TR></TABLE>
lol me too. Rainx does wonders.
Old Jul 12, 2006 | 11:11 AM
DarkBB4's Avatar
Default Re: (98vtec)
my job
BEFORE:
AFTER:
SWEEETTT!!!!
this gives me an idea *lightbulb*
Old Jul 12, 2006 | 11:14 AM
98vtec's Avatar
moderator emeritus
still got some work to do. I wish ABS wasnt so damn tedious to remove.
Old Jul 12, 2006 | 11:37 AM
MadCityLude
Guest
Posts: n/a
I actually did an ABS removal on a 93 lude SI for a friend, and it wasn't that bad really! Took a few hours with the engine out!
Old Jul 12, 2006 | 12:07 PM
soundbomber's Avatar
yeah but with the 5th gen there's no non-abs alternative, that i'm aware of at least.
Old Jul 12, 2006 | 12:10 PM
98vtec's Avatar
moderator emeritus
Default Re: (soundbomber)
correct.
Old Jul 12, 2006 | 12:17 PM
w0rd, but a clean lookin engine bay is all in the routing of wires and attention to detail.
MadCityLude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">yeah but with the 5th gen there's no non-abs alternative, that i'm aware of at least.</TD></TR></TABLE>
Well if the 4th gen master is the same as the 5th then you should be able to do it! All you need to do is fab your own brake lines!
That is if the masters are interchangeable? Anyone know for sure?
If you were to check the 93-95 SI ABS master number with the 5th gen ABS master number they may still use the same setup!
Old Jul 12, 2006 | 12:23 PM
https://honda-tech.com/zero...age=1 there's a lot to be learned from this thread, i know 98vtec has seen it already, but thought i'd share it for the other lude people who don't venture to appearance/cosmetic.
i love when a motor looks like it's just floating in the engine bay.
Old Jul 12, 2006 | 12:26 PM
20_00_lude's Avatar
hey darkbb4 did you paint your valve cover yourself or did you have someone do it for you (plain paint or powder coat). and if you did it yourself what kind of paint did you use???
Old Jul 12, 2006 | 01:23 PM
MadCityLude
Guest
Posts: n/a
Default Re: (20_00_lude)
I did mine myself, used high heat paint and baked it in the oven for like 2 hrs after the final coat!
Old Jul 12, 2006 | 01:57 PM
hu's Avatar
hu
Isnt this an important piece to have? Not for emissions but for fuel reasons? Sorry...Im not too familiar with it.
