Compression with spray ?
Old Jul 17, 2006 | 05:25 PM
kornerk12's Avatar
Default Compression with spray ?
Possible to spray on 14.5:1 compression ? Obviously a low compression setup would be safer but with a good tuner I want to know if this is possible.
Old Jul 17, 2006 | 05:39 PM
petern101's Avatar
Default Re: Compression with spray ? (kornerk12)
how did you get 14.5 compression?
and if you did get a good tuner, shouldn't you be asking him? i know there are some pretty nice ludes on here, but i don't recall many having a 14.5 compression ratio. so it might be slim pickings
Old Jul 17, 2006 | 09:29 PM
kornerk12's Avatar
Default Re: Compression with spray ? (petern101)
Ive seen them on custom builds.
https://honda-tech.com/zero...age=6
Go down to hseriesmm's post
And yes i will talk to the tuner but i was just seeing if anyone else had any input.
Old Jul 17, 2006 | 09:32 PM
hu's Avatar
hu
IMO, spray would be good. NOS simply increases the amount of oxygen, which is good.
Old Jul 17, 2006 | 09:36 PM
kornerk12's Avatar
Default Re: (hu)
You think i would have problems with detonation with such a high compression ratio ?
Old Jul 17, 2006 | 09:55 PM
hu's Avatar
hu
Your tuning and octane will determine this. Is this for a street car?
Old Jul 17, 2006 | 10:13 PM
kornerk12's Avatar
Default Re: (hu)
Its a weekend car/track car. Car wont be spraying often only while at the strip
Old Jul 17, 2006 | 10:56 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">Possible to spray on 14.5:1 compression ? Obviously a low compression setup would be safer but with a good tuner I want to know if this is possible. </TD></TR></TABLE>
Hell no! There is a such thing as to much compression for nitrous. Optimium compression would be 11.5:1 to 12.0:1 for N20. Ask any tuner about a nitrous H22 or any honda motor for that fact on 14.5:1 and nitrous and see what they say. Just my 2 cent but what do I know
Old Jul 18, 2006 | 02:05 PM
kornerk12's Avatar
Default Re: Compression with spray ? (md23vtec)
ooo really...well i guess that works out better then
Old Jul 18, 2006 | 04:53 PM
cubish's Avatar
ive done it...made near 500hp on just spray with a built type r motor...went 10.69@136 in a full bodied street car
Old Jul 18, 2006 | 05:16 PM
AzCivic1.6's Avatar
run higher octane fuel, retard timing, get correct heat range plugs.
Old Jul 18, 2006 | 05:17 PM
cubish's Avatar
Default Re: (AzCivic1.6)
i was running c16 gas..msd retard box.. and ngk 9's
ef_si
Jul 25, 2013 02:09 PM
SantaAnaFerio
11
Dec 15, 2009 03:06 PM
ITR.00-1282
Mar 30, 2003 09:04 AM
wm5holla
Jan 7, 2003 07:06 AM
