ATTS Light.
Old Jul 13, 2006 | 02:19 PM
Wsteun's Avatar
Default ATTS Light.
I made a left-hand turn today from a stop, the car falls flat on its face and the ATTS light comes on. The CEL light is not on however. I was wondering what could've caused this? It was raining, could it be that the tire slipped? or hit a bump? I really don't know. This is the second time this has happened, the first time while it was dry. Any suggestions?
Old Jul 13, 2006 | 02:58 PM
vinuneuro's Avatar
Default Re: ATTS Light. (Wsteun)
Get the code...
Old Jul 13, 2006 | 03:53 PM
Wsteun's Avatar
Used an OBDII sensor, said there was no code... Unhooked the battery and put it back on. ATTS light is off but I've got a new problem. I bought the car used and I don't think it came with the code for the radio.
Old Jul 13, 2006 | 03:55 PM
vinuneuro's Avatar
Default Re: (Wsteun)
Look at what came with the manual. OBDII scanner will not pull atts codes. You have to manually get it.
Old Jul 13, 2006 | 03:59 PM
Wsteun's Avatar
Default Re: (vinuneuro)
Went through all the **** in the glove box and I don't have a damn thing.
How do you pull it manually? the paperclip trick?
Old Jul 13, 2006 | 04:31 PM
vinuneuro's Avatar
you might have to go to the dealer to get it recoded then, or suck it up and use this as an oppur to buy a new neadunit...someone else can chime in.
yes...the paperclip trick.
Old Jul 13, 2006 | 04:54 PM
Wsteun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">you might have to go to the dealer to get it recoded then, or suck it up and use this as an oppur to buy a new neadunit...someone else can chime in.
Not! apparently dealerships/honda hide the code to the radio elsewhere in the car. So you get the card with the code, but it's also hidden on the car. I found my code, it was hidden in the trunk area right next to the trunk light.
Old Jul 13, 2006 | 05:07 PM
vinuneuro's Avatar
very cool
now get out there and pull that code
Old Jul 13, 2006 | 05:25 PM
Wsteun's Avatar
lol code's gone, i disconnected the battery. Light went off.
Old Jul 13, 2006 | 07:16 PM
Black Raven
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wsteun &raquo;</TD></TR><TR><TD CLASS="quote">lol code's gone, i disconnected the battery. Light went off.</TD></TR></TABLE>
yup, that's what i did when i had my prelude
deanwashere
Jul 25, 2018 04:28 AM
slayne
May 18, 2010 07:01 PM
wreckz
Jun 26, 2005 07:46 AM
kitboi826
Apr 3, 2005 02:52 PM
eL
Oct 25, 2003 05:25 AM
