Vacuum Lines
Old Jul 11, 2006 | 06:03 PM
snowblind7x's Avatar
Default Vacuum Lines
I looked at a vacuum line diagram for a H22 and it showed that the nipple that is blocked off in this pic had a line connecting it to the EVAP purge control diaphragm valve. Where is that? I don't see a EVAP canister or control valve at all...
Old Jul 11, 2006 | 06:06 PM
Missing Gears's Avatar
Default Re: Vacuum Lines (snowblind7x)
the evap canister/valve is on the car, and you normally use a smaller vaccum port to run to the canister.
Old Jul 11, 2006 | 06:19 PM
Default Re: Vacuum Lines (Missing Gears)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">the evap canister/valve is on the car, and you normally use a smaller vaccum port to run to the canister.</TD></TR></TABLE>
the diagram i was referring to was the picture found in this post: https://honda-tech.com/zerothread?id=933645 Where exactly is the evap canister? I don't see it...
Old Jul 11, 2006 | 06:31 PM
Actually, the nipple you see in the lower left hand corner of the picture coming off the throttle body is also showed to have a line going to the EVAP purge control diaphragm valve in the diagram, but i don't know where that is...
Old Jul 11, 2006 | 06:34 PM
SKDRCR's Avatar
it's located underneath where the stock intake is,
near the battery.
a little box maybe 4" X 3"
Old Jul 11, 2006 | 07:30 PM
Default Re: Vacuum Lines (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">it's located underneath where the stock intake is,
near the battery.
a little box maybe 4" X 3"</TD></TR></TABLE>
eh...can't find it...Am I just retarded or what...? Or is this a piece that could have possibly been deleted with the swap?
Old Jul 11, 2006 | 07:35 PM
Rosko's Avatar
couldve been deleted, it should be right below the fuel filter on the firewall, its about 4 inches in diameter, and maybe 7 inches long.
wadsworth
May 12, 2008 09:24 AM
Kaspk
Apr 6, 2007 03:12 PM
invisible
Mar 13, 2007 10:35 AM
sldcivic
Jan 18, 2006 09:14 AM
Tyson
18
Nov 4, 2003 05:41 PM
