How to pull codes on 5th gen
Old Jul 15, 2006 | 10:56 AM
HS2G's Avatar
Default How to pull codes on 5th gen
Well my check engine light came on today and i stopped by autozone to have the code pulled. They looked under the steering wheel column tosee where the plug in was and it wasn't there, then they looked under the hood and it wasn't there. So where is the little plug in?
Old Jul 15, 2006 | 11:00 AM
DIRTYsouthBB6's Avatar
1. The diagnostics plug is on the passenger's-side of the car behind a small carpeted panel that snaps on and off.
2. No matter what the moron at AutoZone tells you, don't buy anything until you get our advice as to what your problem is.
Old Jul 15, 2006 | 11:12 AM
HS2G's Avatar
Default Re: (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">1. The diagnostics plug is on the passenger's-side of the car behind a small carpeted panel that snaps on and off.
2. No matter what the moron at AutoZone tells you, don't buy anything until you get our advice as to what your problem is.</TD></TR></TABLE>
Gotcha
Old Jul 15, 2006 | 05:05 PM
Dameltajo's Avatar
thats right............ next to the panel that holds the radio and Ac controls but just a little below down by the carpet. if u needed more info.
did u change anything lately in u car?
Old Jul 15, 2006 | 06:09 PM
HS2G's Avatar
Default Re: (Dameltajo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dameltajo &raquo;</TD></TR><TR><TD CLASS="quote">
did u change anything lately in u car?</TD></TR></TABLE>
Ok, I just went to autozone again and had them pull the code. The code they pulled was P0133, and the guy said my o2 sensor is bad. Could there be something else? He looked up how much one would cost and the Bosch OEM cost 249.99!!! But then the denso OEM only cost 52.99. So how is it so much in difference.
Old Jul 15, 2006 | 06:45 PM
Dameltajo's Avatar
Default Re: (HS2G)
just get the denso,, i had the same when i replaced my cat for a test pipe then i put brand new denso 02,,,,,,,no problem after 2 years.
Old Jul 15, 2006 | 06:51 PM
HS2G's Avatar
Sounds good, I guess i'll just get that.
bigj505
Dec 13, 2005 03:38 PM
fw190bvi
Dec 11, 2005 02:27 PM
Takumi Fujiwara
Jul 25, 2005 06:53 AM
shauniewalnuts
13
Oct 24, 2003 07:14 AM
luder714
Jun 6, 2002 09:33 AM
