resetting computer???
Old Jul 16, 2006 | 02:11 PM
HondaPH22's Avatar
Default resetting computer???
how do you reset the computer to get the check engine light off? i tried unplugging the battery for 30 mins and it didnt work. Honda dealership always do something else to get it off???? need some help here
Old Jul 16, 2006 | 02:22 PM
Hawkze_2.3's Avatar
Default Re: resetting computer??? (HondaPH22)
if the problem that caused the CEL is fixed, then unplugging the battery for 30 seconds will be fine. You need to fix the problem first that caused the light.
If your response is "I did fix it", my response is "No you didn't".
What's the CEL for?
Old Jul 16, 2006 | 02:41 PM
md23vtec's Avatar
Default Re: resetting computer??? (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">if the problem that caused the CEL is fixed, then unplugging the battery for 30 seconds will be fine. You need to fix the problem first that caused the light.
What's the CEL for?</TD></TR></TABLE>
Couldnt have said it better myself
Old Jul 16, 2006 | 04:34 PM
TruNinja619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPH22 &raquo;</TD></TR><TR><TD CLASS="quote">how do you reset the computer to get the check engine light off? i tried unplugging the battery for 30 mins and it didnt work. Honda dealership always do something else to get it off???? need some help here</TD></TR></TABLE>
take out the clock fuse which is located on the fuse box, under the hood...
Old Jul 17, 2006 | 09:29 AM
DIRTYsouthBB6's Avatar
Default Re: resetting computer??? (TruNinja619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 &raquo;</TD></TR><TR><TD CLASS="quote">
take out the clock fuse which is located on the fuse box, under the hood... </TD></TR></TABLE>
+1... that's the easiest way, plus you don't need any tools to do it
Old Jul 17, 2006 | 09:26 PM
HondaPH22's Avatar
Default Re: resetting computer??? (DIRTYsouthBB6)
this is the code coming up, I was tryiing to see if the CE light would come on again. PO141 02 sensor heater circuit malfunction bank 1 sensor 2. Is this the one in the cat converter??
thermostate82
Jan 24, 2009 01:11 AM
nix94delsol
Jan 22, 2008 05:38 PM
D C 5
Jun 15, 2007 12:36 PM
vinuneuro
Apr 9, 2006 08:02 PM
Cielmerlion
Feb 21, 2005 01:21 PM
