Electrical problem
Old Jul 26, 2006 | 06:34 PM
97BB6Type-SH's Avatar
Default Electrical problem
today i was comin home and pulled in to the gas station and realized my fog lights werent working. i have the usdm fogs and had yellow bulbs in them with no problems but now they jus dont turn on. all the other lights are fine jus the fogd wont turn on. can they have burnt out at the same time? also i wanted to know cuz today i was putting up my windows and turn off the car when they werre half way and they still go up and down as long as i dont put the lock on. is that normal? i have a 97 prelude type-sh. thanks
Old Jul 26, 2006 | 08:30 PM
JasonST's Avatar
Default Re: Electrical problem (97BB6Type-SH)
I'd try checking the fuses to see if u've blown one, I'm not sure exactly which one to look for cause I don't have a prelude. Maybe somone else might be able to tell u excactly which one. But check the fuses under ur dash first, then check to see if u got a wire short somewhere, that would be my bet.
Old Jul 27, 2006 | 08:31 AM
Jagan'92's Avatar
windows will go up and down until ten minutes after the car is off or the door opens, whichever comes first.
both fogs could have burnt at the same time, especially if you had cheap yellows and a voltage spike, but more likely is a blown fuse.
Old Jul 27, 2006 | 08:34 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: Electrical problem (Jagan'92)
or the relay?
Draiga1988
Jan 4, 2012 03:33 PM
Lunchbox88
Jan 10, 2008 01:37 PM
defaced8
Aug 27, 2007 05:35 PM
Eightfuns
May 18, 2005 06:29 AM
Layziebtnh055
Apr 24, 2004 09:49 AM
