4gen e-brake
Old Jul 28, 2006 | 01:32 PM
msinsky14's Avatar
Default 4gen e-brake
my e-brake is really weak and does not lock up at all, would getting new rotors and pads help make it lock up while driving or doing burnouts??? already tightened it and barely helped, or are they just weak and the prelude is heavy so its all bad?
Old Jul 28, 2006 | 03:54 PM
soundbomber's Avatar
Default Re: 4gen e-brake (msinsky14)
you probably need new pads and rotors.
far be it for me to criticize your car, but it's pretty stupid to use your handbrake for anything other than parking your car.
Old Jul 28, 2006 | 04:50 PM
msinsky14's Avatar
Default Re: 4gen e-brake (soundbomber)
yeah ur right but I cant help it, I just got this car and I just want it to be perfect..........the first engine blew up b/c of an oil leak, the second engine blew up as well and it had only 38,000 miles on it!!!!.......I dont even drive it hard, is it normal for prelude engines to have this many problems????...or am I just unlucky?.....i guess I'm just over reacting to such a little problem
Old Jul 28, 2006 | 05:03 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">my e-brake is really weak and does not lock up at all, would getting new rotors and pads help make it lock up while driving or doing burnouts??? already tightened it and barely helped, or are they just weak and the prelude is heavy so its all bad?</TD></TR></TABLE>
its called a parking brake for a reason...
Old Jul 28, 2006 | 05:47 PM
shiux's Avatar
maybe you ripping the ebrake around every corner tokyo drift style is hurting your car? food for thought.
Old Jul 29, 2006 | 01:24 PM
msinsky14's Avatar
Default Re: (shiux)
nope, i had the car for 1 month when the engine blew up and never whipped it around corners, its been like that snce I bought it
Old Jul 31, 2006 | 10:38 PM
Attaus's Avatar
The e-brake does not work through your standard brakes.
It's a hydraulic drum inside the rear disc. Ever wonder why it was slightly deeper? You may need a new spring or something. I have the same problem.. maybe I should take a look.
Old Aug 1, 2006 | 10:44 AM
msinsky14's Avatar
Default Re: (Attaus)
what are you talking about???
Old Aug 2, 2006 | 10:35 AM
Attaus's Avatar
Have you ever taken apart a brake assembly before?
Old Aug 2, 2006 | 10:41 AM
M2B4's Avatar
im my experiences prelude motors have treated me well. i think your either unlucky or you dont know how to take care of a motor. could be your unlucky that you dont know how to take care of one i dont know but if you have 2 motors blow on u your doing something wrong.
Old Aug 2, 2006 | 11:30 AM
msinsky14's Avatar
Default Re: (M2B4)
i didnt do anything myself, shops did it all and its all stock.........i didnt drive it hard at all, the first engine with 118,000 miles on it had a cracked block and it wasnt my fault........i only drove it 500 miles when it blew, and the second only 20 miles, the coolant somehow kept pooring into the engine, the top rad. hose was burning hot and the bottom hose cold, im not 100% sure exactly what happed though
Old Aug 2, 2006 | 04:50 PM
paulwithap's Avatar
you can tighten the cable
Old Aug 2, 2006 | 04:59 PM
SKDRCR's Avatar
Default Re: (paulwithap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulwithap &raquo;</TD></TR><TR><TD CLASS="quote">you can tighten the cable</TD></TR></TABLE>
Check the pad wear on the e-brake as well.
Old Aug 3, 2006 | 09:29 PM
paulwithap's Avatar
yeah, i just found out today my pads are worn down to the metal at the tops and are grinding my rotors. luckily i didn't have my radio on for once, and i finally heard it. damage isn't too bad on mine but yeah, check that ****.
Old Aug 3, 2006 | 09:34 PM
tacticalcustoms's Avatar
4TH GEN ebrake isn't that effective anywayz... I replaced my rotors, pads and tighten my cable and it still felt loose.... honda didn't create and ebrake to do hardcore drifting if thats what you want...
Old Aug 4, 2006 | 05:32 PM
paulwithap's Avatar
have you ever taken apart YOUR brake assembly? on most cars, the e-brake doesn't use the regular brakes, but preludes do. i just replaced my pads and calipers today.
Old Aug 4, 2006 | 05:53 PM
ECX's Avatar
ECX
* B A N N E D *
oem or what?
Old Aug 4, 2006 | 05:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulwithap &raquo;</TD></TR><TR><TD CLASS="quote">have you ever taken apart YOUR brake assembly? on most cars, the e-brake doesn't use the regular brakes, but preludes do. i just replaced my pads and calipers today.</TD></TR></TABLE>huh?
Old Aug 6, 2006 | 09:01 PM
paulwithap's Avatar
aboos
25
Dec 27, 2006 05:27 PM
vart
21
Jul 17, 2006 01:25 PM
Soon_2b_evil
53
Apr 6, 2005 04:01 PM
Pullig
Jan 14, 2005 04:42 PM
2k1 itr
Sep 15, 2003 06:59 AM
