Another fix another problem (Boosted Prelude)
Old Jul 23, 2006 | 09:01 AM
ragethemachine86's Avatar
Default Another fix another problem (Boosted Prelude)
Alright i was having alot of problems with my setup. For example one of the cables that went from the ecu to the s200b came out of the connector and i didnt notice until today. Fixed that and everything runs alot better.
Basically i have 2 questions.
1. I drove the car the other day when hondata came in and it went into boost but it was hesitating up top past 6k rpms. Mind you my setup isnt fine tuned yet so i only tried once and headed back to my garage. After fixing the cable today i was going to give it one more try to see if anything changed. Now when i drive and floor it the engine just cuts out right away. No sputtering/hesitating i just get thrown forward so i let off gas. What are these symptoms of?
2. This is regarding hondata. My hondata is tuned for 440cc but one of the injectors no longer works so i temporarily installed 350cc injectors. (This for one could be the cause for problem mentioned in question #1). I would obviously have to set my tune to 350cc's but can this be done without doing the whole burning a new chip routine? I don't know much about tuning hondata since im rrelying on a local tuner for that. I could just get it tuned right away however i dont want to do this yet because i still have to get a 3" DP made and get my 3" exhaust. Dont wanna tune it for open DP or stock exhaust cuz then i have to go back for another tune in a month. By the way the tune i have is for a greddy turbo kit of my friends prelude running same psi. I know this isnt the right tune for my exact setup but it should at least run fine. I wont be beating on it for at least another month or so but i shouldnt be having these problems. So is it simply an issue of having injectors 100cc smaller than hondata thinks and not getting enough fuel or is there something im overlooking.
Thanks for any input, Johnny.
b20EGvtec
Jun 14, 2009 06:57 AM
ragethemachine86
Jul 24, 2006 07:50 AM
JDEM1
Feb 1, 2005 11:30 AM
AlphaKennyWun
Oct 15, 2002 04:33 AM
servion
Aug 11, 2002 12:02 PM
