Control Arms?
Old Oct 25, 2009 | 08:01 PM
Outlaw-Hondaz's Avatar
Default Control Arms?
looking for some control arms..lower and upper. I tried to Google it and got nothing much. What you guys using or do you know about another thread with answers to my question. for 1999 honda prelude sh...thanks
Old Oct 25, 2009 | 09:05 PM
jlude90's Avatar
Default Re: Control Arms?
why do you need new lcas?
Old Oct 25, 2009 | 11:53 PM
TheJGB3's Avatar
X2
all that can wear out is the two bushings #11 (LCA to frame), & #12 (shock fork)(which are replaceable).
Usually what wears out are the balljoints (which are connected to the knuckle/spindle #3 & #4)
Old Oct 26, 2009 | 06:05 PM
well my car is slammed and it is eating the inner sidewall...what can i do to prevent this...i thought it was the lcas.
Old Oct 26, 2009 | 07:27 PM
jlude90's Avatar
that would be upper control arms, the SPC kit or whatever you people run
Old Oct 26, 2009 | 07:51 PM
TheJGB3's Avatar
MOOG makes an adjustable upper balljoint for SH models. It is adjustable +/- 1 degree
Available at Carquest for $79ea. (lifetime warranty)
The part# is K90490
Old Oct 27, 2009 | 06:12 AM
minilogoguy18's Avatar
It's more the toe being out, get some adjustable rear toe links and get an alignment.
Old Oct 28, 2009 | 02:24 AM
TheJGB3's Avatar
What's wrong with adjusting the stock ones? As long as the bolts aren't seized or the arm bent from an accident they should be fine. Preprelude who has the 'best Prelude in the World' thread on PO .com, bought aftermarket (Megan Racing?) ones for his JR SC Type Sh said they suck.
Old Oct 28, 2009 | 07:10 AM
^I have been using them for about a year with no probs. I read his thread, he ran over a pot hole the size of an open man hole, that's what ruined his. >_>
You can only adjust the stock ones so far, so if you have anything more than a slight drop the toe will still be out.
Old Oct 28, 2009 | 07:20 AM
NirVTEC's Avatar
Raise car? Problem solved?
702SI
Suspension & Brakes
May 12, 2017 07:00 AM
kornerk12
Aug 3, 2008 09:10 AM
extracrunchie
Dec 20, 2004 09:47 AM
Lude2die4
Sep 8, 2004 12:58 PM
