Confused
Got a 95 coupe and i was gonna go f22 block with a h22 head on boost both are built, I mean machined port and polish, the works. Yet now im hearing that i should put a single cam accord vtec head on my block instead. any ideas would help.
why would you want a SOHC head?? that makes no sense - yea you'll have reliability but no power at all - the head is what makes our motors, bottom ends suck - also in reality the only advantage of the f block is that its not FRM cylinder walls, which is easy fix if you just build your block for boost from the get go...
just bc it has one cam doesnt mean its not worth building with the right setup(cams,compression ratio,good tune)SOHC can blow by a DOHC and yes this is coming from a DOHC owner
sivtechatchy
Jan 13, 2020 11:03 AM
sivtechatchy
Mar 6, 2009 03:45 AM
