+15 offset?
Old Nov 4, 2009 | 06:47 AM
x22xhyper's Avatar
Default +15 offset?
will a 16x7 or even a 16x8 +15 offset wheel work on a 4th gen lude??
Old Nov 4, 2009 | 06:52 AM
A Blue Lude's Avatar
Default Re: +15 offset?
no
Old Nov 4, 2009 | 07:24 AM
NirVTEC's Avatar
Someones chasing the Low Offset+Negative camber craze!
Some of this will help you make them fit, now you just need a 4 color engine bay and you're ready for Honda Tuning Magazine.
Old Nov 4, 2009 | 01:10 PM
Apex1972's Avatar
Old Nov 4, 2009 | 06:08 PM
x22xhyper's Avatar
haha thanks guys
Old Nov 4, 2009 | 07:11 PM
HondaVerno's Avatar
itll fit hahaha...roll fenders, maybe extended studs
Old Nov 4, 2009 | 07:14 PM
AznBlueBoy's Avatar
i had 16x7 +15 offset
they fit but stick out of the fenders a bit and rubbed.
Old Nov 4, 2009 | 07:17 PM
HondaVerno's Avatar
yep yep they will stick out a tad bit. mine sticks out about an inch
Old Nov 4, 2009 | 07:28 PM
That doesn't sound a whole lot like fitting...
Old Nov 4, 2009 | 08:16 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
They'll mount.
..assuming the lug pattern is right and the hub is thin enough to fit without extended studs.
I'm going to put on 16x7 +25 as soon as I buy tires. I'm just rolling/cutting fenders.. Mine don't look "deep dish" though.
Old Nov 4, 2009 | 11:55 PM
AznBlueBoy's Avatar
well the tires were too wide at 225 and the car is lowered a bit too much. If it was only lowered 1" or so. Would be fine. Definately will fit if at stock height.
Old Nov 5, 2009 | 11:47 AM
Ride height does not determine if something fits or not...
Old Nov 5, 2009 | 12:35 PM
blklude5g's Avatar
yessir its all camber and toe
cehcivic15
Feb 9, 2012 12:36 PM
ef9robert
May 7, 2008 09:38 PM
awalp
Nov 22, 2006 09:35 AM
bard329
Dec 7, 2005 07:11 AM
killaj12
Sep 4, 2005 08:34 AM
