overheating problems!
Old Oct 26, 2009 | 06:06 PM
H22Abeast's Avatar
Icon3 overheating problems!
hey my car is over heating really bad, I changed the thermostat, changed a couple of hoses and I even changed my radiator but the only thing is I havge a half sized radiator and im still over heating, do anyone one think that the radiator i put in is to small for the engine it a h22a vtec please help !!
Old Oct 26, 2009 | 06:08 PM
oneprelude's Avatar
Default Re: overheating problems!
i dont think it would overheat, but at the same time, why would you put a smaller radiator in?
Old Oct 26, 2009 | 06:18 PM
96ludedude's Avatar
did you replace the thermostat gasket?
and if so did you get the right one?
also when you bought a new radiator did you get a new radiator cap with it?
or this could possibly be your ECT sensor going out.
that tends to happen in our cars pretty frequently from what ive seen.
H22Abeast's Avatar
its what I had at the time in my garage..
Old Oct 26, 2009 | 06:22 PM
H22Abeast's Avatar
I used my old thermostat gasket it was still good ,, or should i change that one to,,and where is the ect senor located?
Old Oct 26, 2009 | 06:27 PM
96ludedude's Avatar
well your thermostat gasket may be it then.
because theres only so many things that can make an engine overheat.
and its pretty much right underneath the dizzy but check on the helms to be 100% sure what your taking out of the engine.
Old Oct 26, 2009 | 06:34 PM
H22Abeast's Avatar
ok ill check that out tomorrow,, and should I put back my regular size radiator back in?
Old Oct 26, 2009 | 06:49 PM
96ludedude's Avatar
honestly from what ive heard from the guys that have been here far longer than I, the half rads are ok for our cars.
in fact if you research around a little, quite a few people have them on boosted cars.
let it be known that those are performance aluminum radiators but theyre on performance boosted cars. So it should be fine
Old Oct 26, 2009 | 06:54 PM
H22Abeast's Avatar
good looking out you've been a great help to me ,,ill keep you posted on the work that im a do tomorrow....
Tic55
Honda Civic (2001 - 2005)
16
Sep 1, 2018 12:13 AM
Cannonfairy
Jun 18, 2015 10:33 AM
Robstunner4
Oct 19, 2006 07:20 PM
IA95civicDX
Sep 10, 2005 10:21 PM
yoshe95si
Dec 25, 2001 05:22 PM
