F22B
Old Nov 18, 2009 | 06:32 AM
codered20102010's Avatar
New User
Default F22B
Ok so im talking to this guy outta jdmenginescorp.com and the F22B motor does not have a knock sensor.....so i was wandering if i jus bought the p39 ecu if i would still have to install a knock sensor, he told me he didnt know? LMAO! if you work in a jdm motor place wouldnt you know that? LOL! Can anyone point me in the right direction.
Thanks!
Old Nov 18, 2009 | 11:35 AM
viper-blue's Avatar
Default Re: F22B
Research is your friend:
http://www.cb7tuner.com/vbb/showthread.php?t=81303
http://www.tegger.com/hondafaq/f22b/index.html
The P39 does not need a knock sensor. Same with the PT3 and PT6 from USDM accords. P39 is over-priced and I can tell you from personal experience it won't make the motor run any better than the PT3 or 6, or the the stock P14 with a knock sensor installed on your F22b.
Lots of options here, but if you want the P39 get your checkbook out.
Old Nov 19, 2009 | 05:33 AM
New User
Default Re: F22B
Ok, So If I Dont Need A Knock Sensor Then I Can Do The Swap And Not Have To Worry Bout Any Lights Coming On Bout A Knock Sensor Or anything In That Matter? I Read Alot Of Forums Bout People Needing Them Or Having Problems With A Knock Sensor....I Got Told When I Was Gunna Put A H23A1 in my car id have to install a knock sensor?......jus tryin to get the help I need.
Thanks For Everyones Help And Time!
Old Nov 19, 2009 | 05:35 AM
pentaq's Avatar
Default Re: F22B
yes H23A1 ECU needs KS for proper work.
Old Nov 19, 2009 | 02:35 PM
viper-blue's Avatar
Default Re: F22B
If your worried about engine lights get a pt3 ecu from a usdm accord. They are 30-50 dollars compared to the 150+ for the p39 ecu, or knock sensor.
I drove my f22b on my p14 from the prelude for months with no troubles. The knock sensor went bad quickly, and I always had a light on. I put the pt3 in and the light went out, but the performance was the same.
Taking it further when I put a f22b ecu in the performance was the same.
In my opinion the pt3 is just perfect considering the price, and lack of knock sensor circuit.
Old Nov 20, 2009 | 04:49 PM
Remiss's Avatar
Default Re: F22B
I ran my F22B on the p14 ... just welded a bolt on the block and threaded the knock sensor in ... never had any problems with the knock sensor after that
motor blew from over reving tho haha ...
gabrielsousa
Nov 4, 2015 04:12 PM
KURUPTinc
Mar 10, 2008 10:26 PM
monty Si-R
Apr 25, 2007 05:26 PM
delslow94
Dec 26, 2002 12:52 PM
