need help
Old Oct 21, 2009 | 01:48 PM
blackprelude92's Avatar
Default need help
so im close to putting this new head in my f22 and i cant figure out how to get the timing belt cover off of the crank to put it in time. i need to know if there is a way to put this bottom end in time before i put this new head on without taking the cover off. please help anyone thanks or post letting me know the piston position or something.
Old Oct 21, 2009 | 02:32 PM
92civlude's Avatar
Default Re: need help
At the flywheel end of the motor, there is a rubber plug on the bellhousing. Remove the plug, look inside the hole, on the block there is a pointer. Rotate the crankshaft until you see a white T, line it up with the pointer. You dont have to remove the front cover to facilitate timing.
Old Oct 21, 2009 | 02:45 PM
will it be a white T on the flywheel or where is it going to be at?
Old Oct 21, 2009 | 02:46 PM
we think we found it but need to know if its like a cross type impint
fastludeh22
Sep 25, 2006 08:25 AM
eye.ha8.u
Aug 7, 2006 12:18 PM
duckmanEG
Jan 21, 2005 08:53 PM
bigboostersx
Dec 16, 2004 01:00 PM
Malachi
Jul 20, 2002 09:14 AM
