shifting problems
Old Oct 20, 2009 | 08:36 PM
grkblood13's Avatar
Default shifting problems
i can dry shift into gears fine but when i am actually driving the car sometimes i have to pretty much force the car into gear. ive read that this could be caused by a bad master cylinder but i have a cable clutch and not a hydraulic clutch. could a bad master cylinder still be the cause of my problem even though i dont have a hydraulic clutch? also, if not then what could be the problem?
Old Oct 21, 2009 | 03:41 PM
grkblood13's Avatar
Default Re: shifting problems
anyone?
Old Oct 21, 2009 | 03:56 PM
THC07's Avatar
this is a prelude?
shifting cables?
Ive stretched a few in the past.
Old Oct 21, 2009 | 04:01 PM
grkblood13's Avatar
its a crx with an h22 swap
Old Oct 21, 2009 | 04:05 PM
THC07's Avatar
unless your H2b id be looking at your cables.
but i cant tell you why it would shift at a stand still, but moving it will not.
what do you mean by dry shifting. is the car running?
Old Oct 21, 2009 | 04:29 PM
grkblood13's Avatar
shifting without the car on "dry shifting"
Old Oct 21, 2009 | 04:40 PM
NirVTEC's Avatar
Cables......I'd be willing to bet you used old ones, not NEW like I suggest. Also, the shifter on your trans may be toast.
Always use new cables when doing an H in a NON-H car.......
Then look into the Zip-Tie trick....lastly, don't fall victim to the H2B hype. You can go plenty fast with an H trans!
Old Oct 21, 2009 | 04:45 PM
grkblood13's Avatar
i have a freshly rebuilt h trans with lsd. trans is not the issue.
Old Oct 21, 2009 | 04:49 PM
NirVTEC's Avatar
damn cables......install new ones, and ZING!
Our shop EG with H trans just went 11.8x stock EuroR internals......
Old Oct 21, 2009 | 05:01 PM
grkblood13's Avatar
wheres a good place to buy the shifter cables?
Old Oct 21, 2009 | 05:02 PM
HOODRICHZEKE's Avatar
most likely the cables. I had the same problem right after i did my h22a swap. if you ran the cable underneath the right side motor mount without tacking the cable to the wheel well the mount will pinch it making it hard to shift and after time it will eventually break the cable and you wont shift at all...I'd listen to the above and check cables. It's not fun when they break randomly. trust me.
Old Oct 21, 2009 | 05:05 PM
summit racing has them for sure. but at 200 bucks for the pair i'd shop around.
Old Oct 21, 2009 | 06:28 PM
THC07's Avatar
what? Summit? you got to be kidding me
Old Oct 21, 2009 | 11:56 PM
No, that's where I got mine. They have to order them so it take a week or so. But where I am located it's the closest auto parts store besides a kragen that takes twice as long to order.
Old Oct 22, 2009 | 03:34 AM
smackdown's Avatar
this cables will fit 4th gen lude??
Old Oct 22, 2009 | 06:18 AM
grkblood13's Avatar
cables have to be from a 92-96 lude
Old Oct 22, 2009 | 07:14 AM
5thgen_er's Avatar
any pics of said crx?
Old Oct 22, 2009 | 03:27 PM
grkblood13's Avatar
only the one i have posted in my garage without the engine in it.
Old Oct 23, 2009 | 04:30 AM
smackdown's Avatar
do you have the part number??? i want to change mine too. thanks
Blackpin93
Sep 28, 2013 04:32 PM
flatblack-h22
Transmission & Drivetrain
Jan 18, 2009 05:12 AM
dumpedeg6
May 5, 2005 10:20 AM
double helix
Dec 5, 2004 10:23 PM
