help with spark plug
Old Oct 21, 2009 | 09:31 AM
h22 kid's Avatar
Default help with spark plug
i drove my car yesterday after a month and when i barely pulled out of my street. my car made a noise like a grinding and then shut off. this morning i pulled the spark plugs out and only one was blown!! any help to why this happened would be great.
Old Oct 21, 2009 | 09:52 AM
night's Avatar
Default Re: help with spark plug
holy ****.
check the top of the pistons for one. the ign timing another.
and for the love of god don't use those gimmick *** bosch plugs
Old Oct 21, 2009 | 10:11 AM
THC07's Avatar
umm, I call BS. lol
Holy **** is right.
n2o cant even do that to a plug. I think you have some foreign material in that cylinder.
Old Oct 21, 2009 | 10:32 AM
h22 kid's Avatar
its not bosch there NGK. and nothing foreign was in there. its an all motor set up and was only tuned for an hour and wasnt fully tuned.... i think i have to pull the head off
Old Oct 21, 2009 | 10:58 AM
night's Avatar
ngk?
those sure look like the bosch 4 electrode.
Old Oct 21, 2009 | 12:00 PM
h22 kid's Avatar
nope i can take a better pic to show its ngk
Old Oct 21, 2009 | 12:17 PM
Simkin314's Avatar
That definitely looks like mechanical damage to me. Just 1 spark plug you say? I would agree, pulling the head may be a good move. I would have immediately jumped on foreign material (as THC07 stated).
Old Oct 21, 2009 | 12:58 PM
THC07's Avatar
otherwise. timing or lean condition are the only other things that could ahve caused something that bad/
Old Oct 21, 2009 | 02:26 PM
h22 kid's Avatar
yeah my motor was running really lean but weird thing was i was barely switching to second!
Old Oct 21, 2009 | 02:36 PM
Simkin314's Avatar
Now that it is mentioned, preignition can really f-up a plug. Lean conditions (i thought) would burn too hot and 'blister' the plug.
Is it possible that 1 plug had a different heat rating versus the others?
Old Oct 21, 2009 | 02:37 PM
THC07's Avatar
no, thats not something that just happen all at once, unless it was a foreign object.
timing and/or lean condittions take time to do something like that.
Old Oct 21, 2009 | 02:38 PM
THC07's Avatar
Heat rating will not do that to this extent. period!
man thats odd. Im still sticking to something snmacking that plug.
Ive melted plugs with N20 many times, and they dont even get that bad before they quit working.
Old Oct 21, 2009 | 02:50 PM
Simkin314's Avatar
Then it's back to something inside the cylinder then. Are you absolutely sure that nothing could possibly be in that cylinder h22 kid?
I don't think it really matters but, which cylinder was it?
Old Oct 21, 2009 | 03:00 PM
flyrod's Avatar
pull the head
Old Oct 21, 2009 | 03:52 PM
THC07's Avatar
yea, either way, you have to pull the head. there is going to be some leftovers of that plug sitting ontop of that piston
Old Oct 21, 2009 | 04:34 PM
h22 kid's Avatar
im positive. it was in cylinder 4 the one closest the the gears! im going to pull the head off tomorrow and make sure the cylinder didnt hit the spark plug. im going to inspect the piston and clean out all the debris. while my head is off im going to fix that spark plug hole because the thread is trash. gonna port and polish the head, valve job, put my high compression valves in there and my s2p3's while its out and sell my s2p2's
Old Oct 21, 2009 | 06:26 PM
THC07's Avatar
you might regret that, unless you plan on a new tune. whats your compression?
Old Oct 21, 2009 | 07:23 PM
h22 kid's Avatar
yeah im going to fully get this bitch tuned.. im using hondata s300 and my cp with my stroker is a bit over 13 and its a 2.5l now
Old Oct 22, 2009 | 12:45 PM
h22 kid's Avatar
got the head off and pictures of what had happened!!! what a sad day for me
Old Oct 22, 2009 | 01:00 PM
Simkin314's Avatar
I'm so sorry... That sucks. If I were to guess, was that due to a valve stem snapping?
Old Oct 22, 2009 | 01:03 PM
h22 kid's Avatar
from the looks of this i would say those valves couldnt handle the pressure. i should have installed my high comp valves when i had the chance. oh well live and learn the stupid way. thanks though
Old Oct 22, 2009 | 09:31 PM
98PR3LUD3's Avatar
Old Oct 22, 2009 | 09:37 PM
dntnedvtec's Avatar
Another one bites the dust...sorry for your troubles....May your H22, RIP...
Old Oct 23, 2009 | 01:45 PM
h22 kid's Avatar
dyno ****ed up my motor. they forgot to tighten down cam gear to spec and it advanced in timing till it couldnt anymore and boom my motor blew
Old Oct 23, 2009 | 01:57 PM
Simkin314's Avatar
THEY OWES YOU MONEYSS
