Light Harness!
Old May 20, 2003 | 10:34 PM
92-h23a1's Avatar
Default Light Harness!
I need to replace my light harnesses for my car. Which ones do I get? I need hi/low's both. Which of these two? 9004,9005,9006,9007,h4, h7
I already know H4 is my low beams. Which is for my high beams?
Old May 20, 2003 | 11:52 PM
PreludeRacer023's Avatar
Default Re: Light Harness! (92-h23a1)
your JDMs have H4s and H1s..the H4 is the hig beam/low beam in the same bulb, and the inner lights are the H1s..peace
Old May 21, 2003 | 03:24 PM
92-h23a1's Avatar
Default Re: Light Harness! (PreludeRacer023)
I'm not talkign about replacing the harness on the headlights, I need new harnesses that connecct to the headlights. I don't know which ones to get. Someone help!
Old May 21, 2003 | 07:53 PM
JUNlemonPrelude's Avatar
if anyone has a answer i need to replace mines also.
Old May 21, 2003 | 08:54 PM
Default Re: Light Harness! (sorruffryder)
your talking about the JDM lights right??? the H4 and h1 bulbs use thier respective harnesses...all it is is a plug that has the three holes with wire coming out to wire up the lights
Old May 21, 2003 | 09:26 PM
92-h23a1's Avatar
Not the headlights. My headlights have its original Harnesses. I'm talking about the wire that leads from my car to the headlight. I need to replace those. My highbeam wiring have been cut off. Therefore I need to buy new lightning wire harnesses to replace those. NOT REPLACE THE ONES ON THE HEADLIGHT!! But replace the wires leading from my car TO the headlights. Hence, which two of these should I buy??
Heavy Duty Wiring Harness
9004, 9005 , 9006, 9007, h4, h7
I already know that I need the H4, but which do I get to replace my highbeam wiring? Which I know that it's H1 but I do not know which wiring. Please Help! Any links or sites could help also!
Old May 22, 2003 | 07:12 PM
92-h23a1's Avatar
bump, help!
Old May 23, 2003 | 01:22 AM
damn ur in the same jam as me yo, my driver side high and low beams wiring grounded out, so i drive with the passanger side working, my jdm headlights look like **** at nite, cant even see that far
Old May 23, 2003 | 08:13 AM
92-h23a1's Avatar
Anyone?
gooblinn258
Jan 11, 2014 01:33 PM
jxhxb
Oct 25, 2007 10:34 PM
benscivic22
Sep 28, 2007 06:44 PM
Nevets
Jun 13, 2004 10:07 AM
gsrintgra98
Jun 8, 2003 08:16 AM
