Coilover Problem
Old May 25, 2003 | 10:16 PM
PAID-$$$'s Avatar
Default Coilover Problem
I know this may sound stupid, but heres the deal. I got my skunk2 coilovers instaled last week, today I decided to lower my car even more. When I tried to adjust the two rings underneath the spring, they are on there so tight I couldnt even move them. Am I retarded or just doing something wrong??? Shouldnt the locking rings adjust easily up and down the coilover sleeve???? Any help would be greatly appreciated..................
Old May 25, 2003 | 10:32 PM
Elkins911's Avatar
Default Re: Coilover Problem (PAID-$$$)
did you unlock it before you tried to adjust them? you need the use the allen wrench to unlock the actual adjustor collor.
Old May 26, 2003 | 12:26 AM
PAID-$$$'s Avatar
Default Re: Coilover Problem (Elkins911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">did you unlock it before you tried to adjust them? you need the use the allen wrench to unlock the actual adjustor collor.</TD></TR></TABLE>
No I dont think so, I didnt even know there is one, can you elaborate please????
Old May 26, 2003 | 02:31 AM
jc836's Avatar
Skunk2 sleeves use a pair of locking rings. They come with a pair of spanners. You MUST release the lower ring before trying to move the upper one. It is also wise to raise the car up and even take off the wheel to get to the sleeve and also releive the pressure on the spring.
Skunk absolutely does NOT use an Allen locking device-that is the setup that Ground Control uses.
Old May 26, 2003 | 07:13 AM
Elkins911's Avatar
Default Re: Coilover Problem (jc836)
either way, it sounds like he didnt unlock the sleeve.
Old May 26, 2003 | 08:42 AM
PAID-$$$'s Avatar
I hear what you guys are saying, the problem is that the rings dont budge. The bottom ring is on super tight and its impossible to move it. Any tips on how to get it loose???
Old May 26, 2003 | 07:01 PM
PAID-$$$'s Avatar
Anyone???
Old May 27, 2003 | 06:18 AM
LudeyKrus's Avatar
like he said above; there's an allen wrench used to loosen the rings before you adjust them, and then you tighten them back up when you're through.
Old May 27, 2003 | 07:27 AM
rjr162's Avatar
Default Re: Coilover Problem (LudeyKrus)
ok again doesn't only ground control use the allen key
Old May 27, 2003 | 12:47 PM
DsITR's Avatar
Default Re: Coilover Problem (rjr162)
Ground Control uses the Allen wrench set up..
he is using Skunk2, therefore stop giving him advice about the allen wrench
Make sure all the grit and grime is out of the threaded body, that makes my GC's harder to rotate..I assume Skunk2 is the same..but since you just got them installed, I highly doubt that part.
Relieve all weight if possible. Make sure your car is jacked up, and remove the wheel. If there is any unsprung weight on the spring, you aren't going to move ****.
Next, there are two locking-rotating, uhhh thingies. (for lack of a better word.)
The bottom one must loosen first, for the top one to move down, and the top one must loosen first to raise it..
You should have two wrenches that came w/you setup, so you can loosen the rotating parts...If not, just grab a big set of pliers and a towel (so you don't scratch em up.) and tell however you purchased the setup to get em to you ASAP.
Old May 27, 2003 | 05:20 PM
PAID-$$$'s Avatar
Default Re: Coilover Problem (dsludefosho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsludefosho &raquo;</TD></TR><TR><TD CLASS="quote">Ground Control uses the Allen wrench set up..
You should have two wrenches that came w/you setup, so you can loosen the rotating parts...If not, just grab a big set of pliers and a towel (so you don't scratch em up.) and tell however you purchased the setup to get em to you ASAP.</TD></TR></TABLE>
Ok cool thanks a lot for your help, although ive already tried what you suggested, I guess they are just tight as a bitch............
Old May 27, 2003 | 05:22 PM
JTCdudeman's Avatar
Master H Technician
wd-40 my man... Thats what you need to spray in them to get them to free up... Everytime i adjust my SKUNK2 coilovers I have to do that.... Dunno why, but they lock good and tight.. Plus, u had em pro installed and they make sure everything is good and tight!!! My advice... Buy a membership to a gy.. Work out for the next 8 months... try moving them again... J/k
Old May 27, 2003 | 10:01 PM
PAID-$$$'s Avatar
Default Re: Coilover Problem (JTCdudeman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTCdudeman &raquo;</TD></TR><TR><TD CLASS="quote">wd-40 my man... Thats what you need to spray in them to get them to free up... Everytime i adjust my SKUNK2 coilovers I have to do that.... Dunno why, but they lock good and tight.. Plus, u had em pro installed and they make sure everything is good and tight!!! My advice... Buy a membership to a gy.. Work out for the next 8 months... try moving them again... J/k</TD></TR></TABLE>
Hey JTC dudeman, since you got skunk2's also what do you do about the treaded ring. What I mean is it is not attached to anything so you gotta hold it tight with something in order to be able to rotate the two adjusting rings. ???
Old May 27, 2003 | 10:12 PM
LJR-LUDE01's Avatar
use WD-40 like JTC said and used the two wrenches at the same time putting pressure against the top locking-rotating, uhhh thingies liek d said and also the bottom one in opposite direction. I use to have skunk2 on my civic and they were a bithc to adjust.
Old May 27, 2003 | 10:14 PM
PAID-$$$'s Avatar
Default Re: (LJR-LUDE01)
ok cool, and if that dont work then what????
Old May 27, 2003 | 11:07 PM
DsITR's Avatar
Default Re: (PAID-$$$)
I know what your saying...the Threaded body is spinning right??
Get a towel and some big *** pliers and have someone else grab the Threaded part (use the towel so you don't mash up the threads.)..then you can turn the two uhhh rotating thingies....hopefully that is.
D, who is glad he got GC coilovers..
If all else fails get a big fuggin cheater bar, put it on the rotating wrenches and kick the ******... make sure not to mess up your fender though.. get a towel or something in between.
Old May 28, 2003 | 09:20 PM
PAID-$$$'s Avatar
Default Re: (dsludefosho)
ya thats what it is, the treaded body moves too. Where can I find this huge *** wrench????
Old May 29, 2003 | 06:48 AM
DsITR's Avatar
Just get some big *** pliers, or some big *** vice grips..
If you get some vice grips, you can lock on to the threaded body (make sure to use a towel so you don't mess up the threads..Just position it so the vice grips lock on, but are wedged against one of the other suspension parts so it doesn't spin.
Old May 29, 2003 | 11:52 AM
PAID-$$$'s Avatar
Ya but you can never get vice grips tight enough using a towel.
They will still spin round wont they???
vbcrixmanz
Jan 10, 2007 12:52 AM
projectej8
Sep 17, 2004 11:10 PM
honda89
Aug 3, 2004 06:30 PM
ykracing
Apr 15, 2003 10:26 AM
MeanGreenEG9
Aug 31, 2002 08:01 AM
