problem starting car
Old May 20, 2003 | 03:34 PM
2gn9gencevg's Avatar
Default problem starting car
ok, I just got a 97 prelude with 80,000 miles on it. When I push the clutch in and turn the key to start the car sometimes nothing happens at all. I have to keep the clutch in and the key turned and then move the steering wheel back and forth. Once the steering wheel hits a certain spot the car starts. Anyone know how I can fix this?
Old May 20, 2003 | 04:10 PM
Shakes's Avatar
space cadet
Default Re: problem starting car (2gn9gencevg)
the wires on your selonoid may be loose. take apart the steering colum and check the connection. resoldering may be nessicary.
Old May 20, 2003 | 04:12 PM
Behan's Avatar
Default Re: problem starting car (shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes &raquo;</TD></TR><TR><TD CLASS="quote">the wires on your selonoid may be loose. take apart the steering colum and check the connection. resoldering may be nessicary.</TD></TR></TABLE>
be careful when working with/around airbag.
Old May 20, 2003 | 04:28 PM
Prelude Vtec 23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2gn9gencevg &raquo;</TD></TR><TR><TD CLASS="quote">ok, I just got a 97 prelude with 80,000 miles on it. When I push the clutch in and turn the key to start the car sometimes nothing happens at all. I have to keep the clutch in and the key turned and then move the steering wheel back and forth. Once the steering wheel hits a certain spot the car starts. Anyone know how I can fix this?</TD></TR></TABLE>
Just a question....when you are turning the key is it turning all the way or does it feel like its stuck until the steering wheel hits that certain point???
Old May 20, 2003 | 04:36 PM
Default Re: problem starting car (Prelude Vtec 23)
Sometimes the key feels stuck and doesn't turn all the way, but then I try again and it usually turns.
Old May 20, 2003 | 04:41 PM
Behan's Avatar
thats the steering wheel lock, if you turn the wheel after you turn the car off it will lock. its a theft prevention thing. anyway when you get in you have to put the key in turn wheel till it unlocks and the turn the key the rest of the way.
Old May 21, 2003 | 05:48 PM
Default Re: problem starting car (93preludevtec)
Its not the steering wheel lock. I have the key turned all the way. Then I have to turn the steering wheel back and forth untill it starts. When it starts, the key NEVER TURNS ANYMORE THAN IT ALREADY HAS. That's how I know it's not the steering wheel lock. And, I usually have to try this like two or three times before it starts. I really want to get this fixed so any help would be appreciated.
Old May 21, 2003 | 06:16 PM
Behan's Avatar
if its not the steering wheel lock its probably a loose wire. disaasemble steering column and check wiring.
Old May 21, 2003 | 06:25 PM
Chinchilla's Avatar
OT: how do you take the steering wheel lock off? I tried once (bored, and since I was messing with the ignition switch I had the car running w/o keys) but I ended up breaking my windshield trying to get those 2 bolts out... in the Helms manual they make it look so easy!
P.S. This was my OWN car, I didn't steal it!
Old May 21, 2003 | 06:44 PM
Thanks. I'll check that out this weekend.
ck123
11
Jun 7, 2006 12:37 PM
beyondspexj
Jan 26, 2006 11:12 PM
daddymaxx
Feb 9, 2004 09:19 AM
socalep3
Jan 27, 2004 07:57 PM
