RPM Guage Is Jumpy...... not a constant increase or decrease.
Old May 28, 2003 | 07:50 PM
b_ricker's Avatar
Default RPM Guage Is Jumpy...... not a constant increase or decrease.
When I accelerate the rpm guage jumps form 2 grand to 4 grand sticks there for a while and drops back down. Just does not show true reading of rpms wondering if it could be the ICM or simply that the needle is sticking.
Thanks
Old May 28, 2003 | 08:42 PM
typeSwarrior's Avatar
Default Re: RPM Guage Is Jumpy...... not a constant increase or decrease. (b_ricker)
If you haven't fooled with your dash any, I don't know what to tell you...but if you have ever installed the indiglo gauges or if a previous owner has fooled with them (if there was a previous owner), then that could be the problem. Back when I first bought my Prelude, I bought indiglos, and the needle would stick because of the surface of the gauges rubbing against them. I took them out because I was tired of it and never had a problem since...then again, I don't know if you have these gauges and if you don't, somebody else may want to answer your question
Old May 28, 2003 | 08:50 PM
sharkcohen's Avatar
It very well could be that your ICM is going out. Be sure that is the problem before you have it replaced, as a new one will cost around $200. If you can get your hands on a distributor with a known good ICM, swap distributors and see if this corrects the problem.
roycivic92
Feb 16, 2008 06:41 PM
DC2IntegraTypeR
Jan 21, 2005 03:18 PM
sir168
Mar 15, 2004 06:09 PM
PoWeRBaN_PaNdA
Aug 28, 2002 02:48 PM
pr0digy1
Jan 27, 2002 03:44 AM
