check engine light is on, O2 sensor maybe?? (HELP!)
Old May 28, 2003 | 07:39 AM
bullet9925's Avatar
New User
Default check engine light is on, O2 sensor maybe?? (HELP!)
Hey my check engine light is on and I think it is my o2 sensor. I have had the O2 sensor set off the check engine light before and took I to honda just to spend 130 bucks for them to tell me that was what it was and they could not do anything about it.
I disconnected the negative battery terminal and the car is ok for about 200 miles and then the check engine light comes on again. I definatly think it is the o2 sensor
How can you get your 5th gen prelude computer to bypass the O2 sensor so the ECU does not go into "saftey mode" or something like that without losing power or anything. What do you all think is the best thing that I should do?
BTW I have a boxer VAFC does this contribute to the problem or does it help!
Thanks!!
Old May 28, 2003 | 07:45 AM
sharkcohen's Avatar
Default Re: check engine light is on, O2 sensor maybe?? (bullet9925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I think it is my o2 sensor. I definatly think it is the o2 sensor. What do you all think is the best thing that I should do?</TD></TR></TABLE>
Stop guessing and check the code: http://www.hondaprelude.to/main_checkengine.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">How can you get your 5th gen prelude computer to bypass the O2 sensor so the ECU does not go into "saftey mode" or something like that without losing power or anything.</TD></TR></TABLE>
You can't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">BTW I have a boxer VAFC does this contribute to the problem or does it help!</TD></TR></TABLE>
It all depends on what is causing the CEL. Check the code!!!
Old May 28, 2003 | 08:09 AM
Elkins911's Avatar
Default Re: check engine light is on, O2 sensor maybe?? (sharkcohen)
excelent reply
Old May 28, 2003 | 09:00 AM
bullet9925's Avatar
New User
Default Re: check engine light is on, O2 sensor maybe?? (Elkins911)
ok i'll check the code later today
thanks
Old May 29, 2003 | 09:38 AM
bullet9925's Avatar
New User
i checked the code and I got 8 long flashes and 1 short. So code 81 right? well i can't find any code that is numbered 81. But there was definatly 8 long flashes so i figure it is code 80 which is exhaust gas recirculation. What could this be caused by? please help me!
Thanks
Andrew
Old May 29, 2003 | 10:19 AM
DubbleD's Avatar
check your egr system for stuff that looks broke or disconnected. i kno your supose to replace the diagphram in the egr valve after so many miles....if this helps any
Old May 29, 2003 | 11:49 AM
bullet9925's Avatar
New User
Default Re: check engine light is on, O2 sensor maybe?? (DubbleD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubbleD &raquo;</TD></TR><TR><TD CLASS="quote">check your egr system for stuff that looks broke or disconnected. i kno your supose to replace the diagphram in the egr valve after so many miles....if this helps any</TD></TR></TABLE>
What is the egr? and what isthe egr valve? where is that stuff located?
Thanks
Old May 29, 2003 | 01:02 PM
1LudeChick's Avatar
My check engine light just came on too. It was on earlier this month but went off in about a week so I thought it may have just been a loose gas cap, but now it is back on. Shark - thanks for the link, hopefully it will help.
Old May 29, 2003 | 01:06 PM
Boostless97Lude
Guest
Posts: n/a
why does everyone always assume that CELs are always caused by O2 sensors?
Old May 29, 2003 | 05:41 PM
bullet9925's Avatar
New User
Default Re: check engine light is on, O2 sensor maybe?? (Boosted97Lude)
i'll tell ya why i always assume its an O2 sensor. Cause my CEL went off likea year ago and i got really scared so i rushed to honda and they charged me 110 dollars just to check my car out and they said that my O2 sensor had caused it. They reset my car and it was fine. The service guy told me that basic bolt on modifications can cause the O2 sensor to do that. Thats why assumed that and it has worked before but it cost me alot of money for 1 hour of work
Any help on the EGR?
skuba
Engine Management and Tuning
Jan 18, 2010 05:45 PM
dre2day
Feb 27, 2008 07:27 PM
01SSAP1
Honda S2000
Sep 4, 2007 09:04 AM
civicsaremean
Jun 24, 2007 08:27 AM
