how do i reset my comp?
Master H Technician
Re: how do i reset my comp? (skimb37)
start, shut down, restart...
or, are you looking for a real reset?
In that case go to start, programs, ms-dos-prompt... The type" format c: "and hit y
Re: how do i reset my comp? (musclefella)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by musclefella »</TD></TR><TR><TD CLASS="quote">You can take the ecu fuse out for a couple of minutes to.</TD></TR></TABLE>
I dont know if there is an actual ECU fuse, but you can reset your ECU by pulling the clock fuse.
Re: how do i reset my comp? (Prelude Vtec 23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Vtec 23 »</TD></TR><TR><TD CLASS="quote">
I dont know if there is an actual ECU fuse, but you can reset your ECU by pulling the clock fuse.</TD></TR></TABLE>
hahaha, i think thats funny that the clock fuse resets the ECU
i know there is one on 4th gens, its in the eng. compartment fuse box
Re: how do i reset my comp? (smslude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smslude »</TD></TR><TR><TD CLASS="quote">Disconnect the negative battery terminal for a few minutes..</TD></TR></TABLE> No fuses required
Re: how do i reset my comp? (93preludevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec »</TD></TR><TR><TD CLASS="quote">
i know there is one on 4th gens, its in the eng. compartment fuse box</TD></TR></TABLE>
Yeah its the 10a clock fuse, it controls the clock, stereo, ECM (ECU), transmission control module and some other stuff. I guess you can call the ECU fuse.
Re: how do i reset my comp? (bboyprelude)
just disconnect ur negative wire and leave it over nite... then then in the morning just plug it back in and warm up your car.
OpTiX619
05-14-2005 10:05 PM
