EGR problems...need help!!
Old Mar 11, 2004 | 07:58 PM
stephenB!'s Avatar
Default EGR problems...need help!!
while cruisnig, my check engine light came on out of the blue. previously, everything was fine. the code was for the knock sensor, and i noticed the car didnt feel so strong. then the idle changed, it would climb to 1700 and fall to 700 over and over. and i jumped the ecu again. now i had codes for the knock sensor and the egr lift sensor.
i replaced the egr valve and warmed up the car. it still couldnt hold idle, but it drove normally and the cel wasnt coming on. it would usually come on after about 5 min of driving, and i was out fot about an hour. the cel eventually came back on and the car wasnt driving normally anymore. i checked it and it was for the EGR again.. i am confused.
has anyone had any similar problems? does anyone know the solution? any and all input is appreciated. i need opinions before i go out and spend money. and i did search before creating this topic.
Old Mar 11, 2004 | 08:12 PM
thehondaguru's Avatar
Default Re: EGR problems...need help!! (TURbb1)
So no knock sensor code anymore?
Old Mar 11, 2004 | 08:15 PM
stephenB!'s Avatar
no more knock sensor code, just the egr
Old Mar 11, 2004 | 08:20 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (TURbb1)
the knock sensor code might come back when you get on it again....free bump
Old Mar 11, 2004 | 08:23 PM
stephenB!'s Avatar
since the light came back on i took it to 6k twice, and i only have the egr code
Old Mar 11, 2004 | 08:52 PM
stephenB!'s Avatar
i was out just now with car running and i was looking under the hood for anything out of place. i found a stray vacum line to thr intake manifold and it put my idle back to a steady 500rpms.. i just have to drive it and see if it is ok....hopefully this is the end of this topic. if it isnt ill ba back
Old Mar 11, 2004 | 08:58 PM
ATS*Mark's Avatar
OG triple OG
could it be the vacuum line from the IM to the EGR
Old Mar 11, 2004 | 09:30 PM
digink's Avatar
Default Re: (Hella_JDM)
dude I recently did a jdm h22 swap in my 4th gen too and EGR was making my car run like straight ****. I ditched the p13 and got a chipped p28 from ih8ricerz and god damn does the car run great. I couldnt find anything wrong with my EGR unless the problem was with the EGR itself. Just my .02 cents.
Old Mar 11, 2004 | 11:12 PM
stephenB!'s Avatar
everything seems fine now since i plugged in the stray vaccum. its driving normally againi think i solved the problem
Old Mar 11, 2004 | 11:13 PM
stephenB!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">could it be the vacuum line from the IM to the EGR </TD></TR></TABLE>
yup! that was the one
Old Mar 12, 2004 | 06:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURbb1 &raquo;</TD></TR><TR><TD CLASS="quote">
yup! that was the one</TD></TR></TABLE>
LOL Thats awesome!
terplaygroun_dc2
Oct 23, 2008 09:38 AM
apeek
Jun 3, 2008 02:26 AM
oranginal
Jul 6, 2006 02:17 PM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
qwklude82
Jan 11, 2003 07:03 PM
