supercharged lude
Old Mar 11, 2004 | 09:42 AM
chrgdlude1's Avatar
Default supercharged lude
I have been havin a problem while daily driving, around 3 to 4 thousand rpms i start to ease into the gas the car while start to jerk like it wants to go but something is holdin it back. But when i race it does fine. drivin at 80mphs at a flat 4000 rpm on I95 the rpm needle started to jump from4 to 7 with out me givin it gas. just seeing if anyone has any ideas.
Old Mar 11, 2004 | 10:55 AM
killa_lude's Avatar
Default Re: supercharged lude (chrgdlude1)
did it drive good before? what kinda of charger is it? more info...
Old Mar 11, 2004 | 02:54 PM
Variable J's Avatar
I had a similar problem due to a loose connection to the ingniter which is in the distributor. It causes misfires thats why your car jerks. Sometimes the connection is good but while accellerating vibration will cause the connection to become loose.
Variable J's Avatar
It also causes the tach to jump around
Old Mar 11, 2004 | 03:01 PM
SKDRCR's Avatar
Default Re: supercharged lude (Variable J)
your ignition switch could also cause your tach to jump around,
but i'm leaning towards the ignitor myself.
Do you have this problem only when the car is warm?
Old Mar 12, 2004 | 12:33 PM
chrgdlude1's Avatar
just drove home from work car was warm pushed clutch in needle dropped from 5000 to 3000 then stop at 3000 then back firred. raced turbo sohc civic the car did fine then put it in 3rd gear eased on it again about 4000 it did it again but i'll check the distributor.
Old Mar 12, 2004 | 08:44 PM
Paluce's Avatar
are you running the JR EMS?
I know the tack jumps around for me in cold weather because the black box was a piece of **** it made the car miss aswell.
my problem was only in very cold weather though...
Old Mar 13, 2004 | 11:31 AM
chrgdlude1's Avatar
Default Re: (Paluce)
yes im using the black box. what should i trade it for?
Old Mar 13, 2004 | 12:05 PM
99spanishGT
Guest
Posts: n/a
Default Re: (chrgdlude1)
hondata or AEM EMS
ludecraze93
Jun 13, 2008 05:06 PM
e-Roc
Jul 3, 2006 02:55 PM
rasta420
17
Aug 1, 2004 05:34 PM
4glude
Oct 21, 2003 08:48 AM
