installing skunk2 valves
Old Mar 11, 2004 | 05:01 PM
skunkd lude's Avatar
Default installing skunk2 valves
when i purchased the whole skunk 2 valvetrain for my stage II camshafts, the guy said installing the valves was an afternoon job. i ordered a new head set to put them in, any tricks i should know about installing them? you'd have to torque them down right? but there wont be any machine shop work needed will there? anyone thats put in skunk 2 valves help me out here, i'd appreciate it, thanks
Old Mar 11, 2004 | 05:03 PM
LudeyKrus's Avatar
I believe you need to have them cut/seated. A machine shop should be able to do it pretty cheap, it just cuts the valve seat so it fits the valve face perfectly.
Then you just pop out the old valves, pop in the new valves, reassemble everything, and voila!
Old Mar 11, 2004 | 09:09 PM
solowerks's Avatar
you need to ream the valve seats to 3 certain angles on a stock valve. Im not sure if the angle is the same for skunk 2 valves but if it is different, skunk 2 will know about
Old Mar 12, 2004 | 10:50 AM
Built2.0Lude's Avatar
I just called up Skunk2 cause im going to be rebuilding my top end as well and they said you shouldnt have to do anything, just pop them in.
Old Mar 12, 2004 | 11:28 AM
LudeyKrus's Avatar
Default Re: (Vtec96Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec96Lude &raquo;</TD></TR><TR><TD CLASS="quote">I just called up Skunk2 cause im going to be rebuilding my top end as well and they said you shouldnt have to do anything, just pop them in.</TD></TR></TABLE>
Somehow I just don't believe that......
At the very least, they should be lapped well.
SupraManAG
Feb 15, 2008 08:48 PM
haggard hatch
Apr 8, 2003 12:03 PM
Black DC2
Sep 4, 2002 10:59 PM
Pinhead
Dec 6, 2001 10:28 AM
