Intake
Old Mar 16, 2004 | 03:48 PM
navediesel's Avatar
Default Intake
I just purchased a '97 type SH lude, and i was wondering what would be the best intake to put on it
Old Mar 16, 2004 | 03:52 PM
PrecisionH23a's Avatar
Default Re: Intake (navediesel)
I am a fan of the AEM cold air intakes.
https://honda-tech.com/zerosearch
That link is your best friend.
Old Mar 16, 2004 | 03:58 PM
Soda Popinski's Avatar
Default Re: Intake (PrecisionH23a)
Well you could get a 3inch CAI off ebay for dirt cheap. Or you could Use your stock intake and rig it up wiht a cold air extension. Sleeper.
Old Mar 16, 2004 | 09:17 PM
stupidfox's Avatar
i've seen ads for the dragon weapon r short ram intakes that show dynos for it vs. a buncha other ones and it said it was the best... otherwise on my 95 i have an aem shart ram and on my 94 i have some $40 Ebay no-name that works just as well and i personally like the sound of more.Happy bidding lol!
Old Mar 16, 2004 | 10:07 PM
VTECRaZeR's Avatar
I got a AEM CAI but I've heard that K&N are better. I know 'cause my friend had one on his turbo gsx and it was definitely I say thicker and it looked more protected vs the under hood heat. And so he said too...lol
Old Mar 16, 2004 | 10:42 PM
Inextricabledrvr's Avatar
do you have any other mods on the car?
Old Mar 17, 2004 | 05:39 PM
Goinfasterthanu's Avatar
Ice man for shure..I had the aem cai and it got hot after the car sat for a few, my ice man gets cool in like 3 minutes at the track....
Old Mar 17, 2004 | 11:18 PM
jji106's Avatar
Type-S with a drop-in K&N filter. Leave the resonator in!
Old Mar 19, 2004 | 10:22 AM
AndyGCT's Avatar
Default Re: Intake (jji106)
stay stock man...either that or order the JDM type-s intake setup...its hella better than AEM or the others because 5th gens whip *** in the lower power band. You will lose power with the AEM but gain it on the top end...The Type-S definitly gets you a stronger read out in the lower power band...I've seen Dynos...I'll try and look for the link, i saw a dyno with stock vs AEM vs JDM intakes...
Old Mar 19, 2004 | 10:45 AM
Daemione's Avatar
Default Re: Intake (AndyGCT)
3" eBay short ram, insulate it, remove the resonator, cut out the metal below the filter to the fender below, and a make some baffles for the filter so it doesn't pull underhood air.
Least amount of money, and the most flow. It's gonna be loud at WOT, no doubt about it, but at anything under half-throttle sounds just like stock.
Old Mar 19, 2004 | 11:52 AM
EFz6er's Avatar
Default Re: Intake (Daemione)
What do you insulate it with???
Old Mar 19, 2004 | 12:53 PM
LudeBoyLeRoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyGCT &raquo;</TD></TR><TR><TD CLASS="quote">stay stock man...either that or order the JDM type-s intake setup...its hella better than AEM or the others because 5th gens whip *** in the lower power band. You will lose power with the AEM but gain it on the top end...The Type-S definitly gets you a stronger read out in the lower power band...I've seen Dynos...I'll try and look for the link, i saw a dyno with stock vs AEM vs JDM intakes...</TD></TR></TABLE>
I REALLY want to see that dyno comparo you refer to!!!! (please find & post it!!)
Anyone else have dynos of TYPE S vs Stock or vs AEM CAI (what I have)?
Does the Type S provide the both of best worlds - more low-end than an AEM & more high-end than stock USDM?
THANKS!
Old Mar 19, 2004 | 01:04 PM
Daemione's Avatar
Default Re: Intake (puddz27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puddz27 &raquo;</TD></TR><TR><TD CLASS="quote">What do you insulate it with???</TD></TR></TABLE>
Header or exhaust wrap works well on a budget. You can find intake tube wraps made specifically for the purpose that look a little nicer, they're around $50 if I remember correctly.
Old Mar 19, 2004 | 06:01 PM
Sicc Mugen's Avatar
stock intake works good on my lude i had aem cold air then cut dat btich in half ,made into a short ram,the aem help at top end, but now i have stock intake back on and i took out the bottom part of the filter so it suck more clean air,cause stock filter works better
Old Mar 21, 2004 | 04:54 PM
nis_SHlude's Avatar
Default Re: Intake (Sicc Mugen)
AEM CAI or the V2 appear to be the best. AEM is a tried and true application for intakes. Id personally have the V2 because in did want a CAI cuz of weather in WI. But, if i had to choice again, the Type S intake is the best compermise(sp?)
Old Mar 21, 2004 | 05:53 PM
Kal's Avatar
Kal
Default Re: Intake (nis_SHlude)
get a type S intake with a high flow filter... lude needs better overall gains, not just top end gain.
Old Mar 21, 2004 | 06:22 PM
98 blacksh's Avatar
Default Re: Intake (Kal)
aem cold air
Black95CivicEx
66
Dec 28, 2008 12:23 PM
ragethemachine86
Mar 4, 2006 08:23 AM
hot_97_lude
Aug 13, 2005 09:29 AM
jeffk182
19
Jul 9, 2004 03:39 PM
dumazn8
16
Jan 3, 2004 05:40 PM
