Type SH CaMs
Old Mar 12, 2004 | 07:33 AM
turbolude831's Avatar
Default Type SH CaMs
I whanyed to ask if type SH cams diferrent than just a regular H22 or are they the same? Thanks
Old Mar 12, 2004 | 01:19 PM
PirateMcFred's Avatar
Default Re: Type SH CaMs (turbolude831)
Well this is what Crower has to say:
and helms says:
4th gen vtec and fifth base (info taken from 2 different publication Helms manuals)
intake gross lift: 11.4 mm .449"
exhaust gross lift: 10.6 mm .417
Fifth SH
intake gross lift: 12.0 mm .472
exhaust gross lift: 11.18 mm .440
But there is some contention about wether or not the cams between 5th base and SH are the same since the part numbers are the same. Same part numbers = same part so they may not be different.
Crowers SH lift info seems to be too close to the Helms' lift numbers for there to really be a difference.
Based on Crowers info and the part number fact I think that they are the same with potential minor differences between earlier USDM H22 models and later USDM models, where they might have changed the ramp speed and whatnot.
hope this helps
the Pirate
Modified by PirateMcFred at 3:37 PM 3/12/2004
Old Mar 12, 2004 | 04:55 PM
vinuneuro's Avatar
Default Re: Type SH CaMs (PirateMcFred)
i thought that the SH had increased cam grind to compensate for the increased wegiht.
Old Mar 13, 2004 | 04:42 AM
5hift's Avatar
Remour says the SH high lobe is 1mm taller than the base lobes. Type S is .5 higher than SH.
Old Mar 13, 2004 | 08:36 AM
NXLude's Avatar
if they are bigger its so small that it really doesnt matter
ssaccord92
Feb 9, 2009 04:50 AM
purpleh22
Jan 18, 2006 11:00 AM
Ntercooled
Dec 20, 2005 11:56 AM
MugenLudenB00st
May 28, 2005 09:41 AM
Trbospnkr
Sep 5, 2003 11:20 PM
