how to remove engine light
do you mean the CHECK ENGINE LIGHT? because if you did something to your car and the CEL is on then something isn't right, and you sould check the code and see what the problem is.
how to do you reset a check engine light or how do you remove the led from you gauge cluster?
to reset the CEL, pull your radio/ecu fuse or unplug the batt. for 15 seconds.
edit: as stated above, make sure you know the code before you reset it.
99IntegraGS
May 3, 2004 07:18 AM
kinda tricky on a 5th gen..... well not really.
